axis-homing-akd-drive.cs
See Axis: Homing 📜 for a detailed explanation of this sample code.
/* This sample application demonstrates drive-based homing with a Kollmorgen AKD drive using the RapidCode .NET API.
AKD Drive-based ASCII homing uses preloaded methods available on the drive.
This allows for homing to be performed entirely in the drive without network latencies producing more accurate results.
Drive homing is the recommended homing strategy since it avoids network latencies by having the drive execute the homing routine.
Console.WriteLine("📜 Axis Homing: AKD Drive");
// check Axis type
if (axis.NetworkNode.TypeGet() != RSINodeType.RSINodeTypeKOLLMORGEN_AKD)
Console.WriteLine("Wrong Axis type. This sample requires an AKD Axis.");
// 1. get the drive ready
axis.OperationModeSet(RSIOperationMode.RSIOperationModeHOMING_MODE); // set mode to homing mode
axis.NetworkNode.AKDASCIICommand("DRV.OPMODE 2"); // set drive operation mode (0=current, 1=velocity, 2=position)
axis.NetworkNode.AKDASCIICommand("HOME.AUTOMOVE 0"); // 0=disabled, 1=homing starts when drive enabled
// Make sure you know your motor's position, velocity, and acceleration units before you send any values
// 2. set limit switches
axis.NetworkNode.AKDASCIICommand("DIN5.MODE 18"); // set digital input modes - DI5 is now positive limit switch
axis.NetworkNode.AKDASCIICommand("DIN5.INV 1"); // set polarity - DI5 is now active when low
axis.NetworkNode.AKDASCIICommand("DIN6.MODE 19"); // set digital input modes - DI6 is now negative limit switch
axis.NetworkNode.AKDASCIICommand("DIN6.INV 1"); // set polarity - DI6 is now active when low
// 3. configure drive homing parameters
axis.NetworkNode.AKDASCIICommand("HOME.MODE 1"); // select homing method (MODE1 = find limit input)
axis.NetworkNode.AKDASCIICommand("HOME.V 20"); // set homing velocity
axis.NetworkNode.AKDASCIICommand("HOME.ACC 200"); // set homing acceleration
axis.NetworkNode.AKDASCIICommand("HOME.DEC 200"); // set homing deceleration
axis.NetworkNode.AKDASCIICommand("HOME.DIR 0"); // set homing direction (0=negative, 1=positive)
axis.NetworkNode.AKDASCIICommand("HOME.P 0"); // set home position
axis.NetworkNode.AKDASCIICommand("HOME.DIST 0"); // set homing distance
axis.NetworkNode.AKDASCIICommand("HOME.MAXDIST 0"); // set max homing distance
axis.NetworkNode.AKDASCIICommand("HOME.IPEAK"); // set peak current
// 4. get the axis ready
axis.ErrorLimitActionSet(RSIAction.RSIActionNONE); // set action to none so we don't get position error while drive is in control
axis.Abort(); // disable axis
axis.ClearFaults(); // clear any faults
axis.AmpEnableSet(true, Constants.AMP_ENABLE_MS); // enable the axis
System.Threading.Thread.Sleep(100); // allow time for amp enable
// 5. start homing
axis.NetworkNode.AKDASCIICommand("HOME.MOVE"); // start homing procedure (active in opmode 2 only)
Console.WriteLine("HOME.MOVE command sent");
// 6. check is homing done
UInt16 statusWord;
int isHomed = 0;
int axisIdx = axis.NumberGet();
while (isHomed != 1) // when isHomed = 1, homing has finished
statusWord = axis.NetworkNode.StatusWordGet(axisIdx);
isHomed = statusWord >> 12; // get 12th bit only - tells us homing is done when it goes high
Console.WriteLine("Axis homed");
// 7. cleanup
axis.OriginPositionSet(0.0); // set origin to 0 (needed for repeated use)
axis.Abort(); // disable the axis
axis.OperationModeSet(RSIOperationMode.RSIOperationModeINTERPOLATED_POSITION_MODE); // restore mode of operation
axis.ErrorLimitActionSet(RSIAction.RSIActionABORT); // restore position error action
Set the origin position.
Set the axis operation mode.
NetworkNode * NetworkNode
Definition rsi.h:7077
Send an ASCII command to a supported Kollmorgen drive.
Get the DS402 status word.
RSINodeType TypeGet()
Get the node type, as determined by the Vendor ID and Product Code.
int32_t NumberGet()
Get the axis number.
Definition rsienums.h:621
Definition rsienums.h:1256
RSINodeType
Valid Node types.
Definition rsienums.h:804
RSIOperationMode
DS402 modes of operation.
Definition rsienums.h:1472
