calculate-acceleration-from-velocity.cpp
See IO: Math Blocks 📜 for a detailed explanation of this sample code.
This sample demonstrates how to use MathBlocks to calculate acceleration
from velocity by subtracting the previous velocity from the current velocity.
int main()
const std::string SAMPLE_APP_NAME = "📜 Math Blocks: Calculate Acceleration from Velocity";
/* CONSTANTS */
/* *NOTICE* The following constants must be configured before attempting to run with hardware. */
const int NUM_AXES = 1; // The number of axes to configure
const int AXIS_INDEX = 0; // The index of the axis to configure
const double VELOCITY = 1.0; // the velocity to move the axis
const double ACCELERATION = 0.123; // something small so we can check the MathBlock is working
// create the Controller
// variables to store initial object counts to restore later (starts at -1 to indicate it has not been set)
int initialMathBlockCount = -1;
// set the exit code to an error value.
int exitCode = -1;
// save initial object counts to restore later
initialMathBlockCount = controller->MathBlockCountGet();
/* SAMPLE APP BODY */
/* Configure the controller object counts */
// normally you would set the number of axes here, but for samples that is handled in the Config::SetupController function
// add the two MathBlocks needed for this sample
const int subtractionMathBlockIndex = initialMathBlockCount;
const int previousVelocityMathBlockIndex = initialMathBlockCount + 1;
controller->MathBlockCountSet(initialMathBlockCount + 2);
// get the axis and make sure the axis is not moving and clear any faults
axis->Abort();
axis->ClearFaults();
// read the configuration of both MathBlocks
MotionController::MathBlockConfig subtractionConfig = controller->MathBlockConfigGet(subtractionMathBlockIndex);
// this index must be greater than the subtraction math block index, so the subtraction data is
// one sample old
MotionController::MathBlockConfig previousVelocityConfig = controller->MathBlockConfigGet(previousVelocityMathBlockIndex);
// set the axis to use the command velocity as the input for the MathBlock
// configure the first MathBlock to subtract the previous velocity from the current velocity
// current velocity:
subtractionConfig.InputAddress0 = axis->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
// previous velocity: (as was calculated by the second MathBlock, so we use its ProcessValue)
subtractionConfig.InputAddress1 =
controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, previousVelocityMathBlockIndex);
// write 1.0 to the first UserBuffer entry so the second MathBlock can use it for multiplication
uint64_t userBufferAddr0 = controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeUSER_BUFFER, 0);
controller->MemoryDoubleSet(userBufferAddr0, 1.0);
// configure the second MathBlock to multiply the current velocity by 1.0 (which we'll use for
// the previous sample's velocity)
previousVelocityConfig.InputAddress0 = axis->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
previousVelocityConfig.InputAddress1 = userBufferAddr0;
// set the MathBlock configurations
controller->MathBlockConfigSet(subtractionMathBlockIndex, subtractionConfig);
controller->MathBlockConfigSet(previousVelocityMathBlockIndex, previousVelocityConfig);
// Wait a sample so we know the RMP is now processing the newly configured MathBlocks
controller->SampleWait(1);
// Set the axis to move with a very small acceleration so we can check the MathBlock is working
axis->AmpEnableSet(true); // Enable the motor.
axis->MoveVelocity(VELOCITY, ACCELERATION);
// Wait several samples so we know the RMP is now processing the move command and accelerating
controller->SampleWait(10);
// Keep in mind firmware velocity is in counts per sample, so we need to convert to UserUnits
// per second squared
double calculatedVelocityDelta = controller->MathBlockProcessValueGet(subtractionMathBlockIndex).Double;
// Reduce the velocity back to 0
axis->MoveVelocity(0, ACCELERATION);
axis->MotionDoneWait(); // Wait for the axis to finish moving.
axis->AmpEnableSet(false); // Disable the motor.
// Convert to UserUnits per second squared
double calculatedAcceleration = calculatedVelocityDelta * controller->SampleRateGet() * controller->SampleRateGet() / axis->UserUnitsGet();
std::cout << "Calculated acceleration from MathBlock: " << calculatedAcceleration << std::endl;
// Check that the newly calculated acceleration is as expected
if (std::abs(calculatedAcceleration - ACCELERATION) <= 0.000001)
std::cout << "The MathBlock is calculating the Axis' acceleration by subtracting previous velocity from current velocity." << std::endl;
exitCode = 0;
std::cerr << "Error: The calculated acceleration does not match the expected value" << std::endl;
exitCode = -1;
exitCode = -1;
if (initialMathBlockCount != -1) { controller->MathBlockCountSet(initialMathBlockCount); }
// Note: The axis count is handled by the Config::Cleanup function
Config::Cleanup(controller);
controller->Delete();
double UserUnitsGet()
@ RSIMathBlockOperationSUBTRACT
Subtraction operation.
Definition rsienums.h:1617
@ RSIMathBlockOperationMULTIPLY
Multiplication operation.
Definition rsienums.h:1618
@ RSIControllerAddressTypeUSER_BUFFER
First location in User Buffer.
Definition rsienums.h:408
@ RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE
the processed value of a math block (must specify object index)
Definition rsienums.h:418
@ RSIDataTypeDOUBLE
double (64-bit floating point)
Definition rsienums.h:793
Definition rsienums.h:451
@ RSIAxisAddressTypeCOMMAND_VELOCITY
Command Velocity.
Definition rsienums.h:456
Definition config.h:147
Definition config.h:81
[SetupController]
Definition config.h:206
Definition helpers.h:87
[NetworkShutdown]
Definition helpers.h:205
[PrintHeader]
Definition helpers.h:221
Definition rsi.h:872
RSIDataType ProcessDataType
Data type for processing.
Definition rsi.h:4360
Definition rsi.h:4353
uint64_t InputAddress0
Definition rsi.h:4354
RSIDataType InputDataType0
Definition rsi.h:4355
uint64_t InputAddress1
Definition rsi.h:4356
RSIDataType InputDataType1
Definition rsi.h:4357
Definition rsi.h:4361
