gcode-units.cs
See Motion: G-Code 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how changing linear units affects G-Code velocity and acceleration setters.
Shows how to work with different unit systems in G-Code and understand the impact on motion parameters.
Console.WriteLine("📜 Motion: G-Code Units");
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 6, minRequiredSampleMultiAxisCount: 1);
// set robot axis labels
// get the 6 axis needed for XYZABC robot
Helpers.CheckErrors(xAxis);
Helpers.CheckErrors(yAxis);
Axis zAxis = controller.AxisGet(Constants.AXIS_2_INDEX);
Helpers.CheckErrors(zAxis);
Axis aAxis = controller.AxisGet(Constants.AXIS_3_INDEX);
Helpers.CheckErrors(aAxis);
Axis bAxis = controller.AxisGet(Constants.AXIS_4_INDEX);
Helpers.CheckErrors(bAxis);
Axis cAxis = controller.AxisGet(Constants.AXIS_5_INDEX);
Helpers.CheckErrors(cAxis);
// configure phantom axes
Helpers.PhantomAxisReset(zAxis);
Helpers.PhantomAxisReset(aAxis);
Helpers.PhantomAxisReset(bAxis);
Helpers.PhantomAxisReset(cAxis);
// set axis labels
xAxis.UserLabelSet(xLabel);
yAxis.UserLabelSet(yLabel);
zAxis.UserLabelSet(zLabel);
aAxis.UserLabelSet(aLabel);
bAxis.UserLabelSet(bLabel);
cAxis.UserLabelSet(cLabel);
// create multi-axis object for joints
int multiAxisMotionSupervisorIndex = controller.AxisCountGet(); // MultiAxis supervisor indices begin after Axis supervisor indices
Axis[] axes = [xAxis, yAxis, zAxis, aAxis, bAxis, cAxis];
// create kinematic model with centimeters
const LinearUnits units = LinearUnits.Centimeters;
const string modelName = "RSI_XYZABC_Centimeters";
const double scaling = 1.0;
const double offset = 0.0;
// build model
builder.UnitsSet(units);
builder.JointAdd(new LinearJointMapping(3, CartesianAxis.Roll) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(new LinearJointMapping(4, CartesianAxis.Pitch) { ExpectedLabel = bLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(new LinearJointMapping(5, CartesianAxis.Yaw) { ExpectedLabel = cLabel, Scaling = scaling, Offset = offset });
// create Robot object
Robot robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, MotionController.AxisFrameBufferSizeDefault);
Helpers.CheckErrors(robot);
// note: to use the above kinematic model you must have a gantry (linear 1:1 kinematics)
// and each linear axis must have its user units scaled to millimeters
// This will return centimeters, initialized from the kinematic model units
Console.WriteLine($"Initial G-Code units: {robot.Gcode.UnitsGet()}");
robot.Gcode.AccelerationRateSet(10); // sets G-Code acceleration to 10 Centimeters per MINUTE squared
robot.Gcode.FeedRateSet(10); // sets G-Code velocity to 10 Centimeters per MINUTE
Console.WriteLine($"Acceleration rate (cm/min²): {robot.Gcode.AccelerationRateGet()}");
Console.WriteLine($"Feed rate (cm/min): {robot.Gcode.FeedRateGet()}");
Console.WriteLine();
robot.Gcode.UnitsSet(LinearUnits.Inches); // this is the same as executing G-Code line G20
Console.WriteLine($"G-Code units after setting to inches: {robot.Gcode.UnitsGet()}");
// Observe that acceleration has been scaled but feed rate has been cleared
Console.WriteLine($"Acceleration rate (in/min²): {robot.Gcode.AccelerationRateGet()}");
Console.WriteLine($"Feed rate (units ambiguous): {robot.Gcode.FeedRateGet()}"); // 0 == no feed rate
// Attempting to load feed-governed motion (G1/G2/G3) will fail without a feedrate
robot.Gcode.Load("G1 X1 Y1\n");
Console.WriteLine("Feed-governed motion loaded successfully. This should not print if exceptions are on.");
catch (RsiError loadError)
Console.WriteLine($"Feed-governed motion failed to load (as expected):\n {loadError.Message}");
// Set the acceleration and feed rate in the new unit domain
robot.Gcode.AccelerationRateSet(10); // sets G-Code acceleration to 10 Inches per MINUTE squared
robot.Gcode.FeedRateSet(10); // sets G-Code velocity to 10 Inches per MINUTE
Console.WriteLine($"G-code units after re-declaring acceleration and feed rate: {robot.Gcode.UnitsGet()}");
Console.WriteLine($"Feed rate (in/min): {robot.Gcode.FeedRateGet()}");
// Loading feed-governed motion should now succeed
Console.WriteLine("Feed-governed motion loaded successfully (as expected)");
catch (RsiError)
Console.WriteLine("Feed-governed motion failed to load. This should never print.");
jointsMultiAxis.AmpEnableSet(false);
jointsMultiAxis.AxisRemoveAll();
const int AXIS_5_INDEX
Default: 5.
Definition _constants.cs:25
const int AXIS_3_INDEX
Default: 3.
Definition _constants.cs:23
const int AXIS_4_INDEX
Default: 4.
Definition _constants.cs:24
const int AXIS_1_INDEX
Definition _constants.cs:21
const int AXIS_2_INDEX
Default: 2.
Definition _constants.cs:22
Definition rsi.h:860
void AxisRemoveAll()
Definition rsi.h:12226
Definition rsi.h:111
