compensator-1d.cs
See Motion: Compensator 📜 for a detailed explanation of this sample code.
const int INDEX_ZERO = 0;
const int INDEX_ONE = 1;
// print compensator info
// get rmp controller
// get & configure axes
// set compensator0
inputAxis: movingAxis,
inputAxisMinimum: MIN,
inputAxisMaximum: MAX,
inputAxisDelta: DELTA,
outputAxis: followerAxis,
table: table0);
// set compensator1
compensatorNumber: INDEX_ONE,
table: table1);
// get results
// print results
// verify compensation
const int AXIS_1_INDEX
Definition _constants.cs:21
Compensator output types.
Definition rsienums.h:1602
RSIAxisMasterType
Definition rsienums.h:1359
