io-sync-outputs.cs
See IO: Input & Output 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to set up Sync Outputs for streaming motion.
Shows how to configure outputs to trigger at specific motion element IDs during streaming motion,
allowing synchronized IO operations with motion control.
using System.Threading;
Console.WriteLine("📜 IO: Sync Outputs");
// ready axis
axis.PositionSet(0);
const int EMPTY_CT = 2; // number of points that remains in buffer before e-stop
const int OUTPUT_INDEX = 0; // digital output index that will be controlled
const int NODE_INDEX = 0; // the EtherCAT Node index
double[] positions = [1.0, 2.0, 3.0, 4.0]; // streaming motion positions
double[] times = [0.5, 0.8, 1, 0.5]; // streaming motion times
int outputEnableID = 2; // motion element ID at which to set output HIGH
int outputDisableID = 3; // motion element ID at which to set output LOW
// create IOPoint for digital output
output0.Set(false); // set output low initially
// enable streaming/sync outputs
// configure sync outputs - turn output HIGH at motion element 2, LOW at motion element 3
axis.StreamingOutputAdd(output0, true, outputEnableID); // turn output HIGH at element ID 2
axis.StreamingOutputAdd(output0, false, outputDisableID); // turn output LOW at element ID 3
Console.WriteLine($"Starting streaming motion with {TOTAL_POINTS} points");
Console.WriteLine($"Output will go HIGH at element ID {outputEnableID}");
Console.WriteLine($"Output will go LOW at element ID {outputDisableID}");
// start streaming motion
axis.MovePT(RSIMotionType.RSIMotionTypePT, positions, times, TOTAL_POINTS, EMPTY_CT, false, true);
// monitor motion and output state
while (!axis.MotionDoneGet())
int currentElement = axis.MotionElementIdExecutingGet();
bool outputState = output0.Get();
Console.WriteLine($"Motion Element: {currentElement}, Output State: {outputState}");
Thread.Sleep(50); // small delay to avoid overwhelming console
axis.AmpEnableSet(false);
axis.StreamingOutputsEnableSet(false); // restore
uint16_t MotionElementIdExecutingGet()
void Set(bool state)
bool Get()
Definition rsi.h:12981
bool MotionDoneGet()
RSIMotionType
Definition rsienums.h:1179
