axis-motion-streaming-pt.cs
See Motion: Streaming 📜 for a detailed explanation of this sample code.
/* Demonstrates PT (Position-Time) streaming motion.
PT motion is the simplest streaming motion requiring only position and time arrays.
The controller calculates velocity and acceleration for each segment.
Console.WriteLine("📜 Axis Streaming Motion: PT");
// configure phantom axis
double[] times = [1, 0.5, 2]; // time deltas for each position (velocity and acceleration calculated by RMP)
axis.MovePT(RSIMotionType.RSIMotionTypePT, // type of PT motion (RSIMotionTypePT, RSIMotionTypeBSPLINE, RSIMotionTypeBSPLINE2)
positions, // positions to reach
times, // time deltas
true); // if this is the last MovePT call (true = final point, false = more points expected)
RSIMotionType
Definition rsienums.h:1179
