SingleAxisSyncOutputs.cpp
Attention
See the following Concept pages for a detailed explanation of this sample: Streaming Motion Sync Outputs.
#include "SampleApps.h"
int SingleAxisSyncOutputs::Run()
/* CONSTANTS */
const int AXIS_COUNT = 1; // Specify how many axes you have.
const double USER_UNITS = 1048576; // Specify your counts per unit / user units. (the motor used in this sample app has 1048576 encoder pulses per revolution)
// IO configuration parameters
const int NODE_INDEX = 0; // Specify which EtherCat Node will be used
const int OUTPUT_INDEX = 0;
const int OUTPUT_ENABLE_ID = 2; // The motion element ID at which to set the output
const int OUTPUT_DISABLE_ID = 3; // The motion element ID at which to set the output
// Motion parameters
const int EMPTY_CT = -1; // Number of points that remains in the buffer before an e-stop
const double POSITIONS[] = { 0.25, 0.50, 0.75, 1.0 }; // These will be the streaming motion 5 positions.
const double TIMES[] = { 0.5, 1.0, 1.5, 2.0 }; // These will be the streaming motion 5 positions' time.
USE_HARDWARE = false;
char rmpPath[] = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)
MotionController* controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
if (USE_HARDWARE)
axis->PositionSet(0); // Make sure motor starts at position 0 everytime.
axis->UserUnitsSet(USER_UNITS); // Change your user units.
axis->AmpEnableSet(true); // Enable the motor.
// Set up the inputs
// Ensure the digital out is set low.
//IOPoint *output0 = IOPoint::CreateDigitalOutput(axis, RSIMotorGeneralIo.RSIMotorGeneralIo16); // Retrieve DOUT 1, Method 1: requires you know the io adress in memory, slightly faster
IOPoint* output0 = IOPoint::CreateDigitalOutput(controller->IOGet(NODE_INDEX), OUTPUT_INDEX); // Retrieve DOUT 1 Method 2: only need to know node index
output0->Set(false);
// Set up Sync Outputs
axis->StreamingOutputsEnableSet(true); // Enable streaming output.
// ENABLE the Sync Output(s)
axis->StreamingOutputAdd(output0, true, OUTPUT_ENABLE_ID); // This will turn DOUT1 High when the streaming motion reaches its 3rd motion point.
axis->StreamingOutputAdd(output0, false, OUTPUT_DISABLE_ID); // This will turn DOUT1 Low when the streaming motion reaches its 4th motion point.
// DISABLE the Sync Output(s)
//axis->StreamingOutputAdd(output0, false, outPutEnableID);
axis->MovePT(RSIMotionType::RSIMotionTypePT, POSITIONS, TIMES, TOTAL_POINTS, EMPTY_CT, false, true); // Start Streaming Motion
printf("Motion started. Waiting to complete.\n");
axis->MotionDoneWait(); // What for Streaming Motion to be done.
printf("Motion Complete. The outputs should have been set\n");
axis->StreamingOutputsEnableSet(false); // Disable Sync Outputs.
axis->AmpEnableSet(false); // Disable the motor.
catch (RsiError const& err)
printf("%s\n", err.text); // If there are any exceptions/issues this will be printed out.
return -1;
return 0;
void Set(bool state)
Definition rsi.h:12981
Definition rsi.h:111
@ RSIMotionTypePT
Definition rsienums.h:1180
@ RSIActionNONE
Definition rsienums.h:1257
