compensator-single-axis.cs
See Motion: Compensator 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to configure a compensator that modifies the motion of itself.
The axis command position is used as the input to apply compensation to the same axis,
useful for correcting mechanical non-linearities or backlash.
Console.WriteLine("📜 Compensator: Single Axis");
const int INDEX_ZERO = 0;
const int MIN = 10;
const int MAX = 110;
const int DELTA = 10;
const double VELOCITY = 20.0;
const double ACCELERATION = 30.0;
const double DECELERATION = 30.0;
const double JERK = 50.0;
// compensator table (values are in raw counts not user units)
// at position: 10 20 30 40 50 ... ... 110
// adjust by: ↓ ↓ ↓ ↓ ↓ ... ... ↓
double[] table = new double[POINTS] { 0, 2, -3, -5, -3, 2, -3, 0, 2, -3, -5 };
// print compensator info
Console.WriteLine("Compensator Table:");
for (int i = 0; i < POINTS; i++)
int inputPos = MIN + (i * DELTA);
Console.WriteLine($"@ Pos: {inputPos}, Compensate by: {table[i]}");
// get rmp controller
controller.CompensatorCountSet(1);
controller.CompensatorPointCountSet(compensatorNumber: INDEX_ZERO, pointCount: table.Length);
// get & configure axis
double originalUserUnits = axis.UserUnitsGet();
axis.UserUnitsSet(1); // For demonstration simplicity, set user units to 1 even for hardware axes, since compensators work in raw counts
// verify the three values are equal before configuring compensator
if (controller.CompensatorPointCountGet(INDEX_ZERO) == table.Length && POINTS == table.Length)
// configure compensator using AXIS_COMMAND_POSITION as input to modify same axis
inputAxis: axis,
inputAxisType: RSIAxisMasterType.RSIAxisMasterTypeAXIS_COMMAND_POSITION,
inputAxisMinimum: MIN,
inputAxisMaximum: MAX,
inputAxisDelta: DELTA,
outputAxis: axis,
table: table);
// command motion
axis.AmpEnableSet(true, Constants.AMP_ENABLE_MS);
axis.PositionSet(MIN);
axis.MoveSCurve(position: MIN + DELTA, VELOCITY, ACCELERATION, DECELERATION, JERK); // move to 2nd point
axis.MotionDoneWait();
// get results
double compPos = axis.CompensationPositionGet();
// print results
Console.WriteLine($"Compensation position: {compPos} (expected: {table[1]})");
axis.AmpEnableSet(false);
axis.UserUnitsSet(originalUserUnits);
// verify compensation
if (compPos != table[1])
double UserUnitsGet()
Compensator output types.
Definition rsienums.h:1602
RSIAxisMasterType
Definition rsienums.h:1359
