path-setup-gantry.cs
See Motion: Path 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to set up a kinematic model with a gantry prime axis.
Shows how to configure a 1:1 geared axis system where two physical axes work together
to control the same cartesian coordinate.
Console.WriteLine("📜 Motion: Path Gantry");
// set robot axis labels
const string yPrimeLabel = "Y-Prime";
// get the 3 axis needed for XY_Yp robot
Helpers.CheckErrors(xAxis);
Helpers.CheckErrors(yAxis);
Axis primeAxis = controller.AxisGet(Constants.AXIS_2_INDEX);
Helpers.CheckErrors(primeAxis);
// configure phantom axes
Helpers.PhantomAxisReset(primeAxis);
// set the expected labels for each axis
xAxis.UserLabelSet(xLabel);
yAxis.UserLabelSet(yLabel);
primeAxis.UserLabelSet(yPrimeLabel);
// the joint index of each axis is the index within the MultiAxis object
// "X-Axis" has joint index 0
// "Y-Axis" has joint index 1
// "Y-Prime" has joint index 2
int multiAxisMotionSupervisorIndex = controller.AxisCountGet(); // MultiAxis supervisor indices begin after Axis supervisor indices
Axis[] axes = [xAxis, yAxis, primeAxis];
const LinearUnits units = LinearUnits.Millimeters;
const string modelName = "RSI_XY_Yp";
builder.UnitsSet(units);
builder.JointAdd(new LinearJointMapping(2, CartesianAxis.Y) { ExpectedLabel = yPrimeLabel, Scaling = scaling, Offset = offset });
// create Robot object where the y and y prime will be geared 1:1
const int motionFrameBufferSize = 50; // this is the minimum valid motion frame buffer size
Robot robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, motionFrameBufferSize);
Helpers.CheckErrors(robot);
Console.WriteLine($"Model name: {robot.ModelGet().NameGet()}");
Console.WriteLine($"Model units: {robot.ModelGet().UnitsGet()}");
Console.WriteLine("Gantry configuration: Y-axis and Y-Prime axis are geared 1:1");
jointsMultiAxis.AxisRemoveAll();
const int AXIS_1_INDEX
Definition _constants.cs:21
const int AXIS_2_INDEX
Default: 2.
Definition _constants.cs:22
void AxisRemoveAll()
Definition rsi.h:12226
