axis-config-userunits.cs
Console.WriteLine("📜 Axis Config: UserUnits");
double defaultUserUnits = 1;
// get defaults
defaultUserUnits = axis.UserUnitsGet();
// Define counts per unit (user units)
// set
axis.ErrorLimitTriggerValueSet(1); // Position error limit trigger (see support page)
// get
double userUnits = axis.UserUnitsGet();
Console.WriteLine($"User Units: {userUnits}");
axis.UserUnitsSet(defaultUserUnits); // restore
Definition _constants.cs:26
double UserUnitsGet()
