userlimit-position-abort.cs
See IO: User Limits 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to configure a user limit to abort motion when a specified position is reached.
The user limit triggers when the command position exceeds the trigger value and executes an abort action.
Console.WriteLine("📜 User Limit: Position Abort");
const int USER_LIMIT_NUMBER = 0;
const double TRIGGER_POSITION = 5.0;
const double MOVE_POSITION = 10.0; // must be past the trigger position
const double VELOCITY = 3.0;
const double ACCELERATION = 2.0;
const double DECELERATION = 2.0;
const double JERK = 50.0;
const int OUTPUT_INDEX = 1;
const int WAIT_FOR_TRIGGER_MILLISECONDS = 5000;
// configure user limits
controller.UserLimitCountSet(1);
// create simulated output
IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, OUTPUT_INDEX);
output0.Set(false); // start with output off
axis.PositionSet(0);
double encoderMultiplier = axis.UserUnitsGet();
// configure user limit condition (trigger when position > TRIGGER_POSITION)
number: USER_LIMIT_NUMBER,
conditionNumber: 0,
logic: RSIUserLimitLogic.RSIUserLimitLogicGT,
addressOfDouble: axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION), // for real axis use actual position
limitValueDouble: TRIGGER_POSITION * encoderMultiplier);
// configure user limit settings (abort action)
action: RSIAction.RSIActionABORT,
actionAxis: axis.NumberGet(),
duration: 0,
singleShot: true);
enabled: true);
Console.WriteLine($"Moving to position {MOVE_POSITION}...");
Console.WriteLine($"User limit will trigger abort at position {TRIGGER_POSITION}");
if (output0.Get())
Console.WriteLine("ERROR: Output should not be triggered yet");
// start motion
axis.MoveSCurve(MOVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK);
// wait for user limit interrupt
RSIEventType interruptType = controller.InterruptWait(WAIT_FOR_TRIGGER_MILLISECONDS);
if (interruptType == RSIEventType.RSIEventTypeUSER_LIMIT)
// note: object number for user_limit interrupts is unscaled, add axis count since there's one user limit per axis
int interruptSource = controller.InterruptSourceNumberGet();
// Interrupt source number uses object count, not just user limit count, so account for axis objects
// E.g., 3 axes + 1 user limit = interrupt source 3 (0-based index)
int expectedSource = USER_LIMIT_NUMBER + initialAxisCount;
if (interruptSource == expectedSource)
Console.WriteLine($"✓ User limit triggered - abort executed");
Console.WriteLine($" Interrupt source: {interruptSource}");
if (output0.Get())
Console.WriteLine(" Output activated successfully");
Console.WriteLine(" WARNING: Output was not activated");
Console.WriteLine($"✗ Got USER_LIMIT interrupt but wrong source (expected: {expectedSource}, actual: {interruptSource})");
Console.WriteLine($"✗ Expected USER_LIMIT interrupt but got {interruptType}");
axis.AmpEnableSet(false);
axis.ClearFaults();
output0.Set(false);
controller.UserLimitDisable(USER_LIMIT_NUMBER);
Console.WriteLine("\nUser limit position abort complete.");
double UserUnitsGet()
void Set(bool state)
bool Get()
Definition rsi.h:12981
int32_t NumberGet()
Get the axis number.
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Definition rsienums.h:451
Trigger types for UserLimits.
Definition rsienums.h:758
