axis-motion-streaming-pt-whilestopping.cs
See Motion: Streaming 📜 for a detailed explanation of this sample code.
/* Demonstrates how to handle PT streaming motion when stopping.
Shows the difference between Stop/Resume to continue appending points,
versus starting fresh motion after stopping.
Console.WriteLine("📜 Axis Streaming Motion: PT While Stopping");
// configure phantom axis
axis.PositionSet(0); // start at position 0
const int points = 3; // points per streaming motion call
const int emptyCount = 2; // e-stop generated if there are this number or fewer frames loaded
double[] first = [0.1, 0.2, 0.3]; // positions for first MovePT call
double[] second = [0.4, 0.5, 0.6]; // positions for second MovePT call
double[] third = [0.7, 0.8, 0.9]; // positions for third MovePT call
double[] time1 = [0.3, 0.3, 0.3]; // time deltas for first MovePT call
double[] time2 = [0.2, 0.2, 0.2]; // time deltas for second MovePT call
double[] time3 = [0.25, 0.25, 0.25]; // time deltas for third MovePT call
axis.MovePT(RSIMotionType.RSIMotionTypePT, first, time1, points, emptyCount, false, false); // start motion and stream points
axis.MovePT(RSIMotionType.RSIMotionTypePT, second, time2, points, emptyCount, false, false); // append points
// after Stop() on streaming motion, you can:
// 1. Resume() to continue appending points to existing motion
// 2. Discard previous points and start new motion
axis.Stop(); // puts axis in STOPPED state
// axis.EStop(); // puts axis in ERROR state (must ClearFaults() before continuing)
// axis.Abort(); // puts axis in ERROR state and triggers AmpEnable(false) (must call AmpEnable(true) before continuing)
Console.WriteLine("Motion stopped.");
axis.MotionDoneWait(); // wait for axis to stop
axis.Resume(); // resume appends next points to existing motion, without Resume(), new points start fresh motion
// append or start new based on Resume() call
axis.MovePT(RSIMotionType.RSIMotionTypePT, third, time3, points, emptyCount, false, true);
void Resume()
Resume an axis.
RSIMotionType
Definition rsienums.h:1179
