axis-motion-point-to-point.cs
See Motion: Point-to-Point 📜 for a detailed explanation of this sample code.
/* This sample demonstrates various point-to-point motion commands for single axis motion.
Shows trapezoidal, S-curve, relative, final velocity, and velocity motion profiles.
Each motion command is followed by MotionDoneWait() to ensure completion before proceeding.
using System.Threading;
Console.WriteLine("📜 Axis Motion: Point to Point");
const double POSITION = 10;
const double VELOCITY = 10;
const double ACCELERATION = 20;
const double DECELERATION = 20;
const double FINAL_VELOCITY = 5;
// configure phantom axis
axis.PositionSet(0);
│ ABSOLUTE │
Console.WriteLine("\n1. Absolute Motion");
axis.MoveTrapezoidal(POSITION, VELOCITY, ACCELERATION, DECELERATION);
Console.WriteLine($" CommandPosition after absolute motion: {axis.CommandPositionGet()} (expected: {POSITION})");
if (!Constants.USE_HARDWARE) Helpers.PhantomAxisReset(axis); // reset
│ S-CURVE │
Console.WriteLine("\n2. S-Curve Motion");
Console.WriteLine($" CommandPosition after s-curve motion: {axis.CommandPositionGet()} (expected: {POSITION})");
│ RELATIVE │
Console.WriteLine("\n3. Relative Motion");
axis.MoveRelative(POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
// move back to start using negative relative motion
axis.MoveRelative(-POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
Console.WriteLine($" CommandPosition after relative motion: {axis.CommandPositionGet()} (expected: 0)");
│ FINAL VELOCITY │
Console.WriteLine("\n4. Final Velocity Motion");
axis.MoveSCurve(POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, FINAL_VELOCITY); // axis continues at final velocity after reaching position
// wait until axis transitions to final velocity
while (axis.StatusBitGet(RSIEventType.RSIEventTypeMOTION_AT_VELOCITY) == false)
Thread.Sleep(100);
Console.WriteLine($" CommandVelocity after final velocity motion: {axis.CommandVelocityGet()} (expected: {FINAL_VELOCITY})");
axis.Stop();
axis.Abort();
axis.ClearFaults();
│ VELOCITY │
Console.WriteLine("\n5. Velocity Motion");
axis.MoveVelocity(VELOCITY, ACCELERATION); // move at constant velocity
// wait until axis reaches target position, then stop
while (axis.CommandPositionGet() < POSITION)
Thread.Sleep(100);
Console.WriteLine($" CommandVelocity after velocity motion: {axis.CommandVelocityGet()} (expected: {VELOCITY}) ");
axis.Stop();
double CommandPositionGet()
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
