userlimit-feedrate.cs
See IO: User Limits 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to configure a user limit to change the feed rate when the axis reaches a specified position.
The user limit triggers when the command position exceeds the trigger value.
Console.WriteLine("📜 User Limit: Feed Rate Change at Position");
const int CONDITION = 0;
const double POSITION_TRIGGER_VALUE = 5.0;
const double DEFAULT_FEED_RATE = 1.0;
const double DESIRED_FEED_RATE = 2.0;
const int DURATION = 0;
// configure user limits
controller.UserLimitCountSet(1);
axis.PositionSet(0);
// set initial feed rate
axis.FeedRateSet(DEFAULT_FEED_RATE);
Console.WriteLine($"Initial Feed Rate: {axis.FeedRateGet()}");
double encoderMultiplier = axis.UserUnitsGet();
// configure user limit condition (trigger when position > POSITION_TRIGGER_VALUE)
number: 0,
conditionNumber: CONDITION,
logic: RSIUserLimitLogic.RSIUserLimitLogicGT,
addressOfDouble: axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION),
limitValueDouble: POSITION_TRIGGER_VALUE * encoderMultiplier);
number: 0,
actionAxis: axis.NumberGet(),
duration: DURATION);
// configure user limit output to change feed rate
number: 0,
limitValueDouble: DESIRED_FEED_RATE,
outputPtr: axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeTARGET_FEEDRATE),
enabled: true);
Console.WriteLine($"Moving to position {POSITION_TRIGGER_VALUE + 1}...");
Console.WriteLine($"Feed rate will change to {DESIRED_FEED_RATE} when position > {POSITION_TRIGGER_VALUE}");
// start motion past the trigger position
axis.MoveSCurve(POSITION_TRIGGER_VALUE + 1);
// verify feed rate changed
double finalFeedRate = axis.FeedRateGet();
Console.WriteLine($"Final Feed Rate: {finalFeedRate}");
if (finalFeedRate == DESIRED_FEED_RATE)
Console.WriteLine("✓ User limit triggered - feed rate changed successfully");
Console.WriteLine($"✗ Feed rate did not change (expected: {DESIRED_FEED_RATE}, actual: {finalFeedRate})");
Console.WriteLine("\nUser limit feed rate change complete.");
double UserUnitsGet()
double FeedRateGet()
Get the axis feed rate.
void FeedRateSet(double rate)
int32_t NumberGet()
Get the axis number.
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Definition rsienums.h:451
Trigger types for UserLimits.
Definition rsienums.h:758
