point-to-point.cpp
See Motion: Point-to-Point 📜 for a detailed explanation of this sample code.
/* This sample app demonstrates how to perform point-to-point motion including
absolute moves, relative moves, S-curve motion, and velocity motion.
#include <cmath>
// helper function to wait for the axis to reach velocity when performing a velocity move or move with final velocity
static void HelperAtVelocityWait(MotionController *controller, Axis *axis, const int timeout)
// the number of samples to wait before checking if the axis is at velocity
const int WAIT_SAMPLES = 100;
int samplesWaited = 0;
controller->SampleWait(WAIT_SAMPLES);
samplesWaited += WAIT_SAMPLES;
if (samplesWaited > timeout)
throw std::runtime_error("Timeout waiting for motion to reach velocity");
int main()
const std::string SAMPLE_APP_NAME = "📜 Motion: Point-to-Point";
/* CONSTANTS */
const int NUM_AXES = 1; // the number of axes to configure
// motion Parameters
const double POSITION_0 = 0; // specify the start position
const double POSITION_1 = 0.5; // specify the position to move to
const double VELOCITY = 1; // specify your velocity - units: UserUnits/Sec
const double ACCELERATION = 10; // specify your acceleration - units: UserUnits/Sec^2
const double DECELERATION = 10; // specify your deceleration - units: UserUnits/Sec^2
const double JERK_PERCENT = 50; // specify your jerk percent (0.0 to 100.0)
const double FINAL_VELOCITY = 0.5; // specify your final velocity - units: UserUnits/Sec
// create the controller
// set the exit code to an error value.
int exitCode = -1;
/* SAMPLE APP BODY */
// normally you would set the number of axes here, but for samples that is handled in the Config::SetupController function
// get the axes
// specify a timeout for waiting for the motion to complete
const int32_t TIMEOUT = 10000;
// clear faults and enable the motor
axis->ClearFaults();
axis->AmpEnableSet(true);
/* Absolute (Trapezoidal) Motion */
std::cout << "Absolute (Trapezoidal) Motion:" << std::endl;
axis->MoveTrapezoidal(POSITION_1, VELOCITY, ACCELERATION, DECELERATION);
axis->MotionDoneWait(TIMEOUT);
axis->MoveTrapezoidal(POSITION_0, VELOCITY, ACCELERATION, DECELERATION);
/* Relative Motion */
std::cout << "Relative Motion:" << std::endl;
axis->MoveRelative(POSITION_1 - POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
axis->MoveRelative(POSITION_0 - POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
/* SCurve Motion */
std::cout << "SCurve Motion:" << std::endl;
axis->MoveSCurve(POSITION_1);
axis->MoveSCurve(POSITION_0);
/* SCurve Motion with Final Velocity */
std::cout << "SCurve Motion with Final Velocity:" << std::endl;
std::cout << "Final Velocity: " << FINAL_VELOCITY << std::endl;
axis->MoveSCurve(POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, FINAL_VELOCITY);
HelperAtVelocityWait(controller, axis, TIMEOUT);
std::cout << "Final Velocity: " << 0 << std::endl;
axis->MoveSCurve(POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, 0);
/* Velocity Move */
std::cout << "Velocity Move:" << std::endl;
std::cout << "Accelerating to velocity: " << VELOCITY << std::endl;
axis->MoveVelocity(VELOCITY, ACCELERATION);
std::cout << "Decelerating to velocity: " << 0 << std::endl;
axis->MoveVelocity(0, DECELERATION);
// return to the original position
// disable the motor
axis->AmpEnableSet(false);
exitCode = 0; // set the exit code to success.
exitCode = -1;
Config::Cleanup(controller);
controller->Delete();
Definition config.h:147
Definition config.h:81
[SetupController]
Definition config.h:206
Definition helpers.h:87
[NetworkShutdown]
Definition helpers.h:205
[PrintHeader]
Definition helpers.h:221
Definition rsi.h:872
