axis-motion-streaming-pvajt.cs
See Motion: Streaming 📜 for a detailed explanation of this sample code.
/* Demonstrates PVAJT (Position-Velocity-Acceleration-Jerk-Time) streaming motion.
PVAJT motion requires position, velocity, acceleration, jerk, and time arrays.
The controller uses all specified motion parameters for each segment.
Console.WriteLine("📜 Axis Streaming Motion: PVAJT");
// configure phantom axis
double[] velocities = [10.0, 20.0, 40.0]; // velocities for each position
double[] accelerations = [4, 4, 4]; // accelerations for each move
double[] jerks = [50, 50, 50]; // jerks for each move
double[] times = [0.4, 0.2, 0.1]; // time deltas for each position
axis.MovePVAJT(positions, // positions to reach
accelerations, // accelerations for each move
jerks, // jerks for each move
times, // time deltas
true); // if this is the last MovePVAJT call (true = final point, false = more points expected)
