axis-homing-ds402-drive.cs
See Axis: Homing 📜 for a detailed explanation of this sample code.
/* This sample application demonstrates drive-based homing with a DS402-compliant drive using the RapidCode .NET API.
Drive-based homing avoids network latencies since the drive executes the homing routine.
Many drives follow the DS402 standard, making this a widely applicable homing method.
This sample configures SDO parameters, manages control word states, and monitors status word for completion.
Console.WriteLine("📜 Axis Homing: DS402 Drive");
const int offsetIdx = 0x607C;
const int offsetSub = 0x0;
const int offsetSize = 4;
const int offsetVal = 0;
const int methodIdx = 0x6098;
const int methodSub = 0x0;
const int methodSize = 1;
const int methodVal = 24;
const int targetSpeedIdx = 0x6099;
const int targetSpeedSub = 0x1;
const int targetSpeedSize = 4;
const int targetSpeedVal = 2;
const int originSpeedIdx = 0x6099;
const int originSpeedSub = 0x2;
const int originSpeedSize = 4;
const int originSpeedVal = 10;
const int accelIdx = 0x609A;
const int accelSub = 0x0;
const int accelSize = 4;
const int accelVal = 100;
const int CTRL_WORD_PREP_HOMING = 15;
const int CTRL_WORD_START_HOMING = 31;
const int DELAY_MS = 20;
const int STATUS_TARGET_REACHED = 0x400; // bit 10: target reached (homing complete)
const int STATUS_HOMING_ATTAINED = 0x1000; // bit 12: homing attained (successful)
const int STATUS_HOMING_ERROR = 0x2000; // bit 13: homing error
// get rmp controller
// 1. configure homing parameters via SDOs writes
axis.NetworkNode.ServiceChannelWrite(offsetIdx, offsetSub, offsetSize, offsetVal); // home offset
axis.NetworkNode.ServiceChannelWrite(methodIdx, methodSub, methodSize, methodVal); // home method (home type)
axis.NetworkNode.ServiceChannelWrite(targetSpeedIdx, targetSpeedSub, targetSpeedSize, targetSpeedVal); // speed during search for switch
axis.NetworkNode.ServiceChannelWrite(originSpeedIdx, originSpeedSub, originSpeedSize, originSpeedVal); // speed during search for zero
axis.NetworkNode.ServiceChannelWrite(accelIdx, accelSub, accelSize, accelVal); // home acceleration
// 2. configure control word for homing
int axisCtrlWordIdx = (int)axis.NetworkIndexGet(RSINetworkIndexType.NetworkIndexTypeCONTROL_WORD_INDEX);
axis.rsiControl.NetworkOutputOverrideValueSet(axisCtrlWordIdx, CTRL_WORD_PREP_HOMING); // control word should be 15 before switching to homing mode
axis.rsiControl.NetworkOutputOverrideSet(axisCtrlWordIdx, true); // override control word
controller.SampleWait(DELAY_MS); // delay to give transitions time
// 3. configure operation mode to homing
axis.OperationModeSet(RSIOperationMode.RSIOperationModeHOMING_MODE);
// 4. home
axis.rsiControl.NetworkOutputOverrideValueSet(axisCtrlWordIdx, CTRL_WORD_START_HOMING); // start homing
bool cancelHome = false;
UInt16 statusWord = axis.NetworkNode.StatusWordGet(Constants.AXIS_0_INDEX);
while ((!cancelHome) && ((statusWord & STATUS_TARGET_REACHED) == 0)) // wait until target reached or cancel
// A timeout that sets cancelHome would be a good idea for this while loop
statusWord = axis.NetworkNode.StatusWordGet(Constants.AXIS_0_INDEX); // update status word
// A short sleep or wait is appropriate so you aren't spamming this call
// evaluate homing result
if ((statusWord & STATUS_HOMING_ATTAINED) == STATUS_HOMING_ATTAINED)
Console.WriteLine("Axis homed successfully");
else if ((statusWord & STATUS_HOMING_ERROR) == STATUS_HOMING_ERROR)
Console.WriteLine("Error occurred during homing");
// clean up
axis.rsiControl.NetworkOutputOverrideSet(axisCtrlWordIdx, false);
// restore mode of operation to your desired control mode (typically CSP mode)
axis.OperationModeSet(RSIOperationMode.RSIOperationModeCYCLIC_SYNCHRONOUS_POSITION_MODE);
Set the axis operation mode.
NetworkNode * NetworkNode
Definition rsi.h:7077
Sets a PDO output directly.
void ServiceChannelWrite(int32_t index, int32_t subIndex, int32_t byteCount, int32_t sdoValue, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault)
Write a number in the SDO.
Get the DS402 status word.
MotionController * rsiControl
Definition rsi.h:5521
Definition rsienums.h:621
RSIOperationMode
DS402 modes of operation.
Definition rsienums.h:1472
RSINetworkIndexType
Definition rsienums.h:1573
