Console.WriteLine("📜 Axis Config: Hardware Limits");
bool ACTIVE_HIGH = true;
bool ACTIVE_LOW = false;
double HW_POS_DURATION_TIME = 0.01; // Positive limit duration (in seconds)
double HW_NEG_DURATION_TIME = 0.01; // Negative limit duration (in seconds)
// set pos & neg limits
axis.HardwarePosLimitActionSet(RSIAction.RSIActionE_STOP);
axis.HardwarePosLimitDurationSet(HW_POS_DURATION_TIME);
axis.HardwareNegLimitActionSet(RSIAction.RSIActionE_STOP);
axis.HardwareNegLimitDurationSet(HW_NEG_DURATION_TIME);
// get pos & neg limits
RSIAction hPosLimAct = axis.HardwarePosLimitActionGet();
bool hPosLimTrigState = axis.HardwarePosLimitTriggerStateGet();
double hPosLimDur = axis.HardwarePosLimitDurationGet();
RSIAction hNegLimAct = axis.HardwareNegLimitActionGet();
bool hNegLimTrigState = axis.HardwareNegLimitTriggerStateGet();
double hNegLimDur = axis.HardwareNegLimitDurationGet();
Console.WriteLine($"Hardware Positive Limit Action: {hPosLimAct}");
Console.WriteLine($"Hardware Positive Limit Trigger State: {hPosLimTrigState}");
Console.WriteLine($"Hardware Positive Limit Duration: {hPosLimDur}");
Console.WriteLine($"Hardware Negative Limit Action: {hNegLimAct}");
Console.WriteLine($"Hardware Negative Limit Trigger State: {hNegLimTrigState}");
Console.WriteLine($"Hardware Negative Limit Duration: {hNegLimDur}");
sets the trigger state.
trigger state return.
Trigger state return.
Sets the trigger state.
Definition rsienums.h:1256
