axis-motion-hold-via-address.cs
See Motion: Hold 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to hold motion using a software address (memory location).
Motion is held until a specific bit pattern is written to the address, useful for custom logic.
using System.Threading;
Console.WriteLine("📜 Motion Hold: via Address");
const int MOVE_DISTANCE = 2;
// configure phantom axis
axis.PositionSet(0);
// get available software address from user buffer
ulong softwareAddress = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 1);
// configure motion hold on software address
axis.MotionHoldUserAddressSet(softwareAddress); // specify the host address
axis.MotionHoldUserMaskSet(0x1); // specify the bit to watch (logic AND)
axis.MotionHoldUserPatternSet(0x1); // bit value that will release the motion hold
// ensure condition is false initially
if (controller.MemoryGet(softwareAddress) != 0x0)
controller.MemorySet(softwareAddress, 0x0);
// enable motion hold
// command motion - will be held
axis.MoveRelative(MOVE_DISTANCE);
Console.WriteLine($"\tFirst motion commanded to move {MOVE_DISTANCE} (held)");
Thread.Sleep(100);
double positionWhileHeld = axis.CommandPositionGet();
Console.WriteLine($"\tPosition while held: {positionWhileHeld} (should be 0)");
// release motion hold by setting the address
controller.MemorySet(softwareAddress, 0x1);
Console.WriteLine("\tReleasing hold via address...");
controller.MemorySet(softwareAddress, 0x0); // reset to false
Console.WriteLine($"\tPosition after release: {axis.CommandPositionGet()} (expected: {MOVE_DISTANCE})");
// command motion again - will be held again
Console.WriteLine($"\tSecond motion commanded to move {MOVE_DISTANCE} (held)");
Thread.Sleep(100);
// release motion hold again
// disable motion hold
// this motion will execute immediately
Console.WriteLine($"\tThird motion commanded to move {MOVE_DISTANCE} (no hold)");
Console.WriteLine($"\tFinal position: {axis.CommandPositionGet()} (expected: {MOVE_DISTANCE * 3})");
// clean up
Definition _constants.cs:26
double CommandPositionGet()
Set the motion hold type.
RSIMotionAttrMask
Definition rsienums.h:1201
RSIMotionHoldType
Definition rsienums.h:1236
