axis-config-settling.cs
/* This sample app demonstrates how to set and get axis settling parameters using
RapidCode .NET API.
Console.WriteLine("📜 Axis Config: Settling");
// get
double posTolFine = axis.PositionToleranceFineGet();
double posTolCoarse = axis.PositionToleranceCoarseGet();
double velTol = axis.VelocityToleranceGet();
double setTime = axis.SettlingTimeGet();
// set
axis.PositionToleranceFineSet(posTolFine); // set fine position tolerance.
axis.PositionToleranceCoarseSet(posTolCoarse); // set coarse position tolerance.
axis.VelocityToleranceSet(velTol); // set velocity tolerance.
axis.SettlingTimeSet(setTime); // set settling time (seconds).
Console.WriteLine($"Position Tolerance Fine: {posTolFine}");
Console.WriteLine($"Position Tolerance Coarse: {posTolCoarse}");
Console.WriteLine($"Velocity Tolerance: {velTol}");
Console.WriteLine($"Settling Time: {setTime}");
double SettlingTimeGet()
Get the Settling time.
double VelocityToleranceGet()
Set the settling time.
