difference-of-position-user-limit.cpp
See IO: Math Blocks 📜 for a detailed explanation of this sample code.
This sample demonstrates how to use MathBlocks and UserLimits to monitor
the position difference between two axes and trigger an action when the
difference exceeds a specified threshold.
#include <map>
#include "helpers.h" // Import our helper functions.
#include "config.h" // Import our configuration.
// Map of the RSIState enum to string
static const std::map<RSIState, std::string> RSIStateMap = {
{RSIState::RSIStateIDLE, "RSIStateIDLE"},
{RSIState::RSIStateMOVING, "RSIStateMOVING"},
{RSIState::RSIStateSTOPPING, "RSIStateSTOPPING"},
{RSIState::RSIStateSTOPPED, "RSIStateSTOPPED"},
{RSIState::RSIStateSTOPPING_ERROR, "RSIStateSTOPPING_ERROR"},
{RSIState::RSIStateERROR, "RSIStateERROR"}
int main()
const std::string SAMPLE_APP_NAME = "📜 Math Blocks: Difference of Position User Limit";
/* CONSTANTS */
const int NUM_AXES = 2; // The number of axes to configure
const int AXIS_X_INDEX = 0; // The index of the first axis
const int AXIS_Y_INDEX = 1; // The index of the second axis
// User Limit Configuration
const double MAX_POSITION_DIFFERENCE = 0.5; // the maximum position difference before the user limit triggers
const RSIAction USER_LIMIT_ACTION = RSIAction::RSIActionABORT; // the action to take when the user limit is triggered
const int USER_LIMIT_DURATION = 0; // the time delay before the action is executed after the User Limit has triggered
// Motion Parameters
const double RELATIVE_POSITION = 2 * MAX_POSITION_DIFFERENCE; // the relative position to move the axes
const double VELOCITY = 1; // the velocity to move the axes
const double ACCELERATION = 10; // the acceleration of the axes movement
const double DECELERATION = 10; // the deceleration of the axes movement
const double JERK_PCT = 0; // the jerk percentage of the axes movement
// Create the controller
// Variables to store initial object counts to restore later (starts at -1 to indicate it has not been set)
int initialUserLimitCount = -1;
int initialMathBlockCount = -1;
int exitCode = -1;
// Prepare the controller as defined in config.h depending on the configuration
// Save initial object counts to restore later
initialUserLimitCount = controller->UserLimitCountGet();
initialMathBlockCount = controller->MathBlockCountGet();
/* SAMPLE APP BODY */
/* Configure the controller object counts */
// Normally you would set the number of axes here, but for samples that is handled in the Config::SetupController function
// Each axis has a motion object associated with it, so we need to add one more motion object than axes
const int multiAxisIndex = controller->AxisCountGet();
controller->MotionCountSet(multiAxisIndex + 1);
const int userLimitIndex = initialUserLimitCount;
controller->UserLimitCountSet(initialUserLimitCount + 1);
const int mathBlockIndex = initialMathBlockCount;
controller->MathBlockCountSet(initialMathBlockCount + 1);
// Get the axes
Axis *axisX = controller->AxisGet(AXIS_X_INDEX);
Axis *axisY = controller->AxisGet(AXIS_Y_INDEX);
// Configure a multiaxis for the two axes
MultiAxis *multiAxis = controller->LoadExistingMultiAxis(multiAxisIndex);
multiAxis->AxisRemoveAll();
multiAxis->AxisAdd(axisX);
multiAxis->AxisAdd(axisY);
multiAxis->Abort(); // make sure the multiaxis is not moving
multiAxis->ClearFaults();
// Read the configuration of the MathBlock
MotionController::MathBlockConfig mathBlockConfig = controller->MathBlockConfigGet(mathBlockIndex);
// Determine which axis address type to use based on the config USE_HARDWARE flag
// Configure the MathBlock to subtract the position of the second axis from the position of the first axis
mathBlockConfig.InputAddress0 = axisX->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
mathBlockConfig.InputAddress1 = axisY->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
// Set the MathBlock configuration
controller->MathBlockConfigSet(mathBlockIndex, mathBlockConfig);
// Wait a sample so we know the RMP is now processing the newly configured MathBlocks
controller->SampleWait(1);
std::cout << "MathBlock configured to subtract the position of the second axis from the position of the first axis." << std::endl;
// Get the address of the MathBlock's ProcessValue to use in the UserLimit
uint64_t mathBlockProcessValueAddress =
// Configure the UserLimit to trigger when the absolute position difference is greater than MAX_POSITION_DIFFERENCE
controller->UserLimitConditionSet(
userLimitIndex, 0, RSIUserLimitLogic::RSIUserLimitLogicABS_GT, mathBlockProcessValueAddress, MAX_POSITION_DIFFERENCE
// Set the UserLimit action to abort motion (Note: since the axes are in a multiaxis, the other axis will also be aborted)
controller->UserLimitConfigSet(
userLimitIndex, RSIUserLimitTriggerType::RSIUserLimitTriggerTypeSINGLE_CONDITION, USER_LIMIT_ACTION, AXIS_X_INDEX,
USER_LIMIT_DURATION
std::cout << "UserLimit configured to trigger when the absolute position difference is greater than " << MAX_POSITION_DIFFERENCE
<< " and abort motion." << std::endl;
// Command motion to trigger the UserLimit
std::cout << "Moving the axes to trigger the UserLimit..." << std::endl;
axisX->AmpEnableSet(true); // Enable the motor.
axisX->MoveRelative(RELATIVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PCT); // Move the axis to trigger the UserLimit.
axisX->MotionDoneWait();
// Disable the motor and the UserLimit
axisX->AmpEnableSet(false); // Disable the motor.
controller->UserLimitDisable(userLimitIndex);
// The motion should have been aborted and both axes should be in an error state
std::cout << "Both axes are in the error state after the UserLimit triggered (This is the intended behavior)." << std::endl;
exitCode = 0;
std::cout << "Error: The axes should be in an error state after the UserLimit triggers, but they are not." << std::endl;
std::cout << "First Axis State: " << RSIStateMap.at(axisX->StateGet()) << std::endl;
std::cout << "Second Axis State: " << RSIStateMap.at(axisY->StateGet()) << std::endl;
exitCode = -1;
exitCode = -1;
if (initialUserLimitCount != -1) { controller->UserLimitCountSet(initialUserLimitCount); }
if (initialMathBlockCount != -1) { controller->MathBlockCountSet(initialMathBlockCount); }
// Note: The axis and motion counts are handled by the Config::Cleanup function
Config::Cleanup(controller);
controller->Delete();
void AxisRemoveAll()
void AxisAdd(Axis *axis)
Definition rsi.h:12226
RSIState StateGet()
@ RSIMathBlockOperationSUBTRACT
Subtraction operation.
Definition rsienums.h:1617
@ RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE
the processed value of a math block (must specify object index)
Definition rsienums.h:418
@ RSIDataTypeDOUBLE
double (64-bit floating point)
Definition rsienums.h:793
@ RSIUserLimitLogicABS_GT
Absolute value is greater than.
Definition rsienums.h:779
Definition rsienums.h:1256
@ RSIActionABORT
Abort - disable the amplifier, zero filter output, leave in error state.
Definition rsienums.h:1264
Definition rsienums.h:451
@ RSIAxisAddressTypeCOMMAND_POSITION
Command Position.
Definition rsienums.h:453
@ RSIAxisAddressTypeACTUAL_POSITION
Actual Position.
Definition rsienums.h:452
@ RSIUserLimitTriggerTypeSINGLE_CONDITION
Only one condition is evaluated.
Definition rsienums.h:761
@ RSIStateSTOPPING
Stopping, on its way to stopped. Note: Cannot use Axis::PositionSet() or Axis::CommandPositionSet() i...
Definition rsienums.h:1018
@ RSIStateSTOPPING_ERROR
Stopping with an error.
Definition rsienums.h:1020
@ RSIStateSTOPPED
Stopped (resumable). Note: Cannot use Axis::PositionSet() or Axis::CommandPositionSet() in this state...
Definition rsienums.h:1019
@ RSIStateMOVING
Moving (without any errors). Note: Cannot use Axis::PositionSet() or Axis::CommandPositionSet() in th...
Definition rsienums.h:1017
@ RSIStateIDLE
Idle, ready for anything.
Definition rsienums.h:1016
Definition config.h:147
Definition config.h:81
[SetupController]
Definition config.h:206
constexpr bool USE_HARDWARE
Definition config.h:40
Definition helpers.h:87
[NetworkShutdown]
Definition helpers.h:205
[PrintHeader]
Definition helpers.h:221
Definition rsi.h:872
RSIDataType ProcessDataType
Data type for processing.
Definition rsi.h:4360
Definition rsi.h:4353
uint64_t InputAddress0
Definition rsi.h:4354
RSIDataType InputDataType0
Definition rsi.h:4355
uint64_t InputAddress1
Definition rsi.h:4356
RSIDataType InputDataType1
Definition rsi.h:4357
Definition rsi.h:4361
