io-dedicated.cs
See IO: Input & Output 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to access Dedicated IO on an axis.
Shows how to read hardware limits, home switch, amp fault, and amp enable signals.
Uses both generic and specific functions for accessing dedicated inputs.
Console.WriteLine("📜 IO: Dedicated");
// retrieve dedicated inputs with generic and specific function.
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInLIMIT_HW_NEG),
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInLIMIT_HW_POS),
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInHOME),
axis.HomeSwitchGet());
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInAMP_FAULT),
axis.AmpFaultGet());
axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInAMP_ACTIVE),
axis.AmpEnableGet());
bool AmpEnableGet()
bool HomeSwitchGet()
bool PositiveLimitGet()
bool NegativeLimitGet()
bool AmpFaultGet()
bool DedicatedInGet(RSIMotorDedicatedIn motorDedicatedInNumber)
Read a digital input.
RSIMotorDedicatedIn
Definition rsienums.h:1025
