compensator-2d.cs
See Motion: Compensator 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to configure and use a 2-dimensional compensator.
A 2D compensation table is applied to a Z axis based on the positions of X and Y axes,
useful for flatness compensation or surface mapping applications.
Console.WriteLine("📜 Compensator: 2D");
const int INDEX_ZERO = 0;
const int X_MIN = 0;
const int X_MAX = 500;
const int X_DELTA = 100;
const int X_POINTS = ((X_MAX - X_MIN) / X_DELTA) + 1; // 6 points
const int Y_MIN = 0;
const int Y_MAX = 500;
const int Y_DELTA = 100;
const int Y_POINTS = ((Y_MAX - Y_MIN) / Y_DELTA) + 1; // 6 points
const int TOTAL_POINTS = X_POINTS * Y_POINTS; // 36 points total
// compensator table values use axis COUNTS (not user units)
// table is organized as rows (X) & columns (Y)
double[] table = new double[TOTAL_POINTS] {
0, 0, 0, 0, 0, 0,
100, 200, -200, 10, 300, 0,
100, 200, -500, 400, 500, 0,
0, 0, 0, 0, 0, 0,
-300, 300, -300, -300, -300, 0,
0, 0, 0, 0, 0, 0,
// print compensator info
Console.WriteLine($"X Range: {X_MIN} to {X_MAX}, Delta: {X_DELTA}");
Console.WriteLine($"Y Range: {Y_MIN} to {Y_MAX}, Delta: {Y_DELTA}");
Console.WriteLine($"Points: {TOTAL_POINTS}");
Console.WriteLine($"2D Compensator Table ({X_POINTS}x{Y_POINTS}):");
for (int i = 0; i < Y_POINTS; i++)
for (int j = 0; j < X_POINTS; j++)
Console.Write($"{table[i * X_POINTS + j],6}");
Console.WriteLine();
// get rmp controller
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 3);
controller.CompensatorCountSet(1);
controller.CompensatorPointCountSet(INDEX_ZERO, table.Length); // set number points allocated on the controller
// get & configure axes
Axis x = controller.AxisGet(axisNumber: Constants.AXIS_0_INDEX);
Helpers.CheckErrors(x);
Axis y = controller.AxisGet(axisNumber: Constants.AXIS_1_INDEX);
Helpers.CheckErrors(y);
Axis z = controller.AxisGet(axisNumber: Constants.AXIS_2_INDEX);
Helpers.CheckErrors(z);
// set position error limit trigger
// init the 2D compensator
firstInputAxis: x,
firstInputAxisType: RSIAxisMasterType.RSIAxisMasterTypeAXIS_ACTUAL_POSITION,
firstInputAxisMinimum: X_MIN,
firstInputAxisMaximum: X_MAX,
firstInputAxisDelta: X_DELTA,
secondInputAxis: y,
secondInputAxisType: RSIAxisMasterType.RSIAxisMasterTypeAXIS_ACTUAL_POSITION,
secondInputAxisMinimum: Y_MIN,
secondInputAxisMaximum: Y_MAX,
secondInputAxisDelta: Y_DELTA,
outputAxis: z,
table: table);
// get results
x.PositionSet(0);
y.PositionSet(0);
double compPos1 = z.CompensationPositionGet();
x.PositionSet(X_DELTA);
y.PositionSet(Y_DELTA);
double compPos2 = z.CompensationPositionGet();
// print results
Console.WriteLine($"Compensation at (0,0): {compPos1} (expected: {table[0]})");
Console.WriteLine($"Compensation at ({X_DELTA},{Y_DELTA}): {compPos2} (expected: {table[7]})");
// verify accuracy
if (compPos1 != table[0] || compPos2 != table[7])
Helpers.AbortMotionObject(x);
Helpers.AbortMotionObject(y);
Helpers.AbortMotionObject(z);
const int AXIS_1_INDEX
Definition _constants.cs:21
const int AXIS_2_INDEX
Default: 2.
Definition _constants.cs:22
Compensator output types.
Definition rsienums.h:1602
RSIAxisMasterType
Definition rsienums.h:1359
