axis-homing-master-based.cs
See Axis: Homing 📜 for a detailed explanation of this sample code.
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsienums.h:621
Definition rsienums.h:1256
