axis-config-stop-rate.cs
Console.WriteLine("📜 Axis Config: Stop Rate");
// get
double stopTime = axis.StopTimeGet();
double eStopTime = axis.EStopTimeGet();
double eStopDeceleration = axis.EStopDecelerationGet();
// set
axis.StopTimeSet(stopTime); // set the default STOP time to STOP_RATE_DEFAULT secs.
axis.EStopTimeSet(eStopTime); // set the default ESTOP time to ESTOP_RATE_DEFAULT secs.
axis.EStopDecelerationSet(eStopDeceleration); // set the default ESTOP time to ESTOP_DECELERATION_RATE secs.
Console.WriteLine($"Stop Time: {stopTime}");
Console.WriteLine($"EStop Time: {eStopTime}");
Console.WriteLine($"EStop Deceleration: {eStopDeceleration}");
double EStopDecelerationGet()
double EStopTimeGet()
double StopTimeGet()
