follow-sensor.cpp
See Real-Time Tasks 📜 for a detailed explanation of this sample code.
This sample demonstrates how to create a Real-Time Task that follows a simulated sensor
value on an axis using Real-Time Tasks.
#include "rttasks-helpers.h" // import our helper functions for RTTasks
#include "rttask.h" // import the RTTask library
#include <iostream>
#include <iomanip>
#include <memory>
#include <optional>
#include <thread>
#include <chrono>
using namespace RSI::RapidCode::RealTimeTasks; // Import the RealTimeTasks namespace
│ Helper functions for logging │
void LogStatus(RTTaskManager& manager, Axis* axis)
std::cout
<< std::setw(8) << manager.StatusGet().CycleCount
<< " | cmd: " << std::setw(8) << std::fixed << std::setprecision(3)
<< axis->CommandPositionGet()
<< " | sens: " << std::setw(8) << std::fixed << std::setprecision(3)
<< manager.GlobalValueGet("sensorValue").Double
<< '\n';
void PrintStatusWhileRunning(RTTaskManager& manager, Axis* axis, int duration=3, int interval=50)
std::cout << "Begin logging" << std::endl;
using clock = std::chrono::steady_clock;
auto start = clock::now();
auto chronoDuration = std::chrono::seconds(duration);
auto chronoInterval = std::chrono::milliseconds(interval);
while (clock::now() - start < chronoDuration) {
LogStatus(manager, axis);
std::this_thread::sleep_for(chronoInterval);
std::cout << "End logging\n" << std::endl;
void PrintGlobals(RTTaskManager& manager)
const auto& globals = manager.GlobalNamesGet();
std::cout << "-----GLOBALS-----\n";
for (const auto& name : globals) {
std::cout << " " << name << '\n';
std::cout << "---END GLOBALS---\n" << std::endl;
void PrintTasks(RTTaskManager& manager)
std::cout
<< "--Tasks------------------------------\n";
for (auto task : manager.TasksGet()) {
const auto& params = task.InfoGet().CreationParameters;
const auto& status = task.StatusGet();
std::cout
<< "Task " << std::right << std::setw(4) << task.IdGet() << " | "
<< std::left << std::setw(14) << params.FunctionName << " | "
<< RTTaskHelper::StateToString(status.State)
<< '\n' << std::right;
std::cout
<< "-------------------------------------\n"
<< std::endl;
│ End helper functions │
int main()
const std::string SAMPLE_APP_NAME = "📜 Real-Time Tasks: Follow Sensor";
/* CONSTANTS */
const int NUM_AXES = 1; // The number of axes to configure, default is 1 for this template
const int TIMEOUT_MS = 5000; // Timeout for waiting for the task to execute once
// create the controller
std::optional<RTTaskManager> manager;
// normally you would set the number of axes here, but for samples that is handled in the Config::SetupController function
// configure the axis
Axis *axis = controller->AxisGet(0);
axis->PositionSet(0);
axis->AmpEnableSet(true);
// create the task manager
RTTaskManagerCreationParameters parameters = RTTaskHelper::GetTaskManagerCreationParameters();
std::cout << "Creating task manager..." << std::endl;
manager = RTTaskManager::Create(parameters);
Helpers::CheckErrors(&manager.value());
// List all globals defined in RTTaskFunctions library
PrintGlobals(manager.value());
// call the initialization task to initialize the global variables and get pointers to RapidCode objects
// in the RTTaskFunctions library. This needs to be called before any task that uses RapidCode objects.
RTTaskHelper::SubmitInitializationTask(manager.value());
// tell the task manager the name of the function to run as a task, the name
// of the library that contains the function, and the directory where the
// library is located. The FollowSensor function is defined in the RTTaskFunctions library.
// It moves the axis back and forth based on a simulated sensor value.
std::cout << "Submitting task..." << std::endl;
RTTaskCreationParameters params("FollowSensor");
params.Period = 10;
RTTask task = manager->TaskSubmit(params);
// Print the submitted tasks
PrintTasks(manager.value());
// Let the task run while we log information
PrintStatusWhileRunning(manager.value(), axis);
// Wait until either the task has run at least 300 times (in total) or 500ms passes
// Stop the task
task.Stop();
axis->MotionDoneWait(TIMEOUT_MS); // The axis might still be moving from the task, so wait for it to finish
axis->AmpEnableSet(false);
// Use the RTTaskStatus struct to check the execution count and state
RTTaskStatus taskStatus = task.StatusGet();
int64_t executionCount = taskStatus.ExecutionCount;
RTTaskState taskState = taskStatus.State;
if (executionCount <= 0)
// the task did not run correctly
exitCode = -1;
std::cout << "Execution count is not greater than 0. The task did not run correctly." << std::endl;
// the task ran correctly
exitCode = 0;
std::cout << "Execution count: " << executionCount << " (>= 300 expected)" << std::endl;
// Print the final axis position
std::cout << "Axis position: " << axis->CommandPositionGet() << std::endl;
// Print the task state
std::cout << "State: " << RTTaskHelper::StateToString(taskState) << " (DISABLED expected)" << std::endl;
std::cerr << e.what() << std::endl;
// shutdown the task manager firmware process
if (manager.has_value())
manager->Shutdown();
Config::Cleanup(controller);
controller->Delete();
double CommandPositionGet()
void Stop()
Stop the task from executing.
RTTaskStatus StatusGet()
Get the current status of the task.
Definition rttask.h:438
RSI::RapidCode::FirmwareValue GlobalValueGet(int32_t offset)
Read a GlobalTag by its offset. (internal use).
RapidVector< RTTask > TasksGet()
Get all tasks managed by this RTTaskManager.
RapidVector< const char * > GlobalNamesGet(const char *const libraryName=nullptr, const char *const libraryDirectory=nullptr)
Get names of all global variables.
RTTaskManagerStatus StatusGet()
Get the current status of the manager.
static RTTaskManager Create(const RTTaskManagerCreationParameters &parameters)
Create a new RTTaskManager instance.
Interface for managing real-time tasks firmware. See Real-Time Tasks for more information.
Definition rttask.h:562
RTTaskState
Enum representing the possible states of a real-time task.
Definition rttask.h:64
Definition config.h:147
Definition config.h:81
[SetupController]
Definition config.h:206
Definition helpers.h:87
[NetworkShutdown]
Definition helpers.h:205
[PrintHeader]
Definition helpers.h:221
The RealTimeTasks namespace.
Definition rttask.h:36
Definition rsi.h:872
Definition rttask.h:126
Definition rttask.h:140
Definition rttask.h:320
int64_t CycleCount
Number of cycles executed by the manager.
Definition rttask.h:292
RTTaskStatus provides status information for a real-time task, including its current state,...
Definition rttask.h:239
RTTaskState State
Current state of the task.
Definition rttask.h:241
Number of times the task has executed.
Definition rttask.h:244
double Double
Definition rsi.h:473
