axis-config-phantom-axis.cs
Console.WriteLine("📜 Axis Config: Phantom Axis");
// get defaults
int DEFAULT_AXIS_COUNT = controller.AxisCountGet();
int DEFAULT_MOTION_COUNT = controller.MotionCountGet();
Console.WriteLine($"Initial Axis Count: {controller.AxisCountGet()}\n");
// add phantom axis
// get phantom axis
Console.WriteLine($"After adding phantom axis..");
Console.WriteLine($"Axis count: {controller.AxisCountGet()}");
Console.WriteLine($"Phantom Axis index: {axisIndex}");
Console.WriteLine($"Motor type: {axis.MotorTypeGet()}");
Console.WriteLine($"Error limit action: {axis.ErrorLimitActionGet()}");
Console.WriteLine($"Hardware negative limit action: {axis.HardwareNegLimitActionGet()}");
Console.WriteLine($"Hardware positive limit action: {axis.HardwarePosLimitActionGet()}");
Console.WriteLine($"Home action: {axis.HomeActionGet()}");
Console.WriteLine($"Software negative limit action: {axis.SoftwareNegLimitActionGet()}");
Console.WriteLine($"Software positive limit action: {axis.SoftwarePosLimitActionGet()}");
Console.WriteLine($"Position tolerance coarse: {axis.PositionToleranceCoarseGet()}");
Console.WriteLine($"Position tolerance fine: {axis.PositionToleranceFineGet()}");
// restore defaults
controller.AxisCountSet(DEFAULT_AXIS_COUNT);
controller.MotionCountSet(DEFAULT_MOTION_COUNT);
Console.WriteLine($"\nRestored Axis count: {controller.AxisCountGet()}");
Set the motor type.
Definition rsienums.h:1256
RSIMotorType
Motor Type.
Definition rsienums.h:1452
