basic-template.cs
See 🧩 Template 📜 for a detailed explanation of this sample code.
/* This is a basic template you can use to get up and running quickly with RapidCode.
It demonstrates simple controller and axis initialization, basic axis configuration,
and how to enable an axis and prepare it for motion.
Console.WriteLine("📜 Basic Template");
// create rmp controller
var createParams = new MotionController.CreationParameters();
#if WINDOWS
createParams.RmpPath = Constants.RMP_WINDOWS_PATH; // default is "C:\RSI\X.X.X"
createParams.NodeName = Constants.RMP_NODE_NAME; // default is "NodeA"
#elif LINUX
createParams.RmpPath = Constants.RMP_LINUX_PATH; // default is root folder "/rsi/"
createParams.NicPrimary = Constants.RMP_NIC_PRIMARY; // default is empty since we do not have a network by default
createParams.CpuAffinity = Constants.RMP_CPU_AFFINITY; // default is 0 since this is what our tests use
#endif
MotionController controller = MotionController.Create(createParams);
Helpers.CheckErrors(controller); // ALWAYS check for errors after creating a RapidCode object
// start the ethercat network
//Helpers.NetworkStart(controller); // uncomment if using real (not phantom) axis. samples use phantoms by default
// get your axis
Helpers.CheckErrors(axis); // ALWAYS check for errors after creating a RapidCode object
// specify the counts per unit/user units
double userUnits = Constants.AXIS_0_USER_UNITS;
axis.UserUnitsSet(userUnits); // they are often used to change counts to distance (cm, inch, etc), degree, full rotation, etc.
// configure axis limits and error handling
axis.ErrorLimitTriggerValueSet(1); // set position error limit trigger
axis.PositionSet(0); // make sure motor starts at position 0
axis.Abort(); // abort any motion
axis.ClearFaults(); // clear faults, resets to IDLE state
axis.AmpEnableSet(true, Constants.AMP_ENABLE_MS); // enable the motor
Console.WriteLine("Axis initialized and ready");
Console.WriteLine($"User Units: {userUnits}");
Console.WriteLine($"Current Position: {axis.CommandPositionGet()}");
Console.WriteLine($"Amp Enabled: {axis.AmpEnableGet()}");
//-----INSERT YOUR CODE HERE-----
axis.AmpEnableSet(false); // disable the motor
controller.Delete(); // delete the controller as the program exits to ensure memory is deallocated in the correct order
Definition _constants.cs:26
const int RMP_CPU_AFFINITY
Definition _constants.cs:9
const string RMP_LINUX_PATH
Default: /rsi.
const string RMP_NIC_PRIMARY
Default: "".
Definition _constants.cs:8
const string RMP_NODE_NAME
Default: NodeA.
Definition _constants.cs:7
const string RMP_WINDOWS_PATH
Default: .....
Definition _constants.cs:5
Definition rsi.h:872
