camming.cs
See Motion: Camming 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to command nonlinear coordinated motion between two axes.
The follower axis position is controlled as a function of the moving axis position.
Moving Axis: may or may not be controlled by the motion controller.
Follower Axis: controlled by the motion controller as a function of the moving axis.
Console.WriteLine("📜 Camming");
const double MOVING_POSITION = 25; // total distance to move on moving axis
// get axes
Axis movingAxis = controller.AxisGet(Constants.AXIS_0_INDEX);
Axis followerAxis = controller.AxisGet(Constants.AXIS_1_INDEX);
// configure phantom axes
// enable phantoms to keep commanded position after motion done
followerAxis.AmpEnableSet(true, Constants.AMP_ENABLE_MS);
// cam profile - relative moving axis distances and absolute follower positions
double[] movingAxisDistances = [4, 8, 12]; // relative distances on moving axis (x-axis) (4 + 8 + 12 = 24)
double[] followerAxisPositions = [10, 20, 15]; // absolute positions for follower axis (y-axis)
// command cam motion on follower before moving axis starts
followerAxis.MoveCamLinear(
masterAxisNumber: movingAxis.NumberGet(),
masterFeedbackSource: RSIAxisMasterType.RSIAxisMasterTypeAXIS_COMMAND_POSITION, // use COMMAND for phantoms, ACTUAL for real axis
masterDistances: movingAxisDistances,
slavePositions: followerAxisPositions,
pointCount: movingAxisDistances.Length);
// command motion on moving axis
movingAxis.MoveRelative(MOVING_POSITION);
// wait for cam motion to complete
followerAxis.MotionDoneWait();
// print results
Console.WriteLine($"Moving axis final position: {movingAxis.CommandPositionGet()}");
Console.WriteLine($"Follower final position: {followerAxis.CommandPositionGet()}");
const int AXIS_1_INDEX
Definition _constants.cs:21
void MoveCamLinear(int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, const double *const masterDistances, const double *const slavePositions, int32_t pointCount)
int32_t NumberGet()
Get the axis number.
RSIAxisMasterType
Definition rsienums.h:1359
