userlimit-estop-store-position.cs
See IO: User Limits 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to configure a user limit that triggers an E-Stop when a digital input goes high.
The axis command position is stored when the user limit triggers.
Example uses Beckhoff IO Terminals (EL1088 for inputs).
Check your digital IO signal indexes in RapidSetup -> Tools -> NetworkIO.
Console.WriteLine("📜 User Limit: EStop and Store Position");
const int AXIS_INDEX = Constants.AXIS_0_INDEX;
const int INPUT_INDEX = 0;
const int CONDITION = 0;
const int USER_DATA_INDEX = 0;
const double DURATION = 0.125; // time delay before action executes (seconds)
// configure user limits
controller.UserLimitCountSet(1);
IOPoint input0 = IOPoint.CreateDigitalInput(controller, userBufferAddress, INPUT_INDEX);
Helpers.CheckErrors(input0);
Axis axis = controller.AxisGet(AXIS_INDEX);
axis.PositionSet(0);
axis.ClearFaults();
// start velocity motion
axis.MoveVelocity(velocity: 10.0, accel: 20.0);
number: 0,
conditionNumber: CONDITION,
// configure user limit settings (e-stop action)
number: 0,
action: RSIAction.RSIActionE_STOP_ABORT,
actionAxis: AXIS_INDEX,
duration: DURATION);
// configure user data to store axis command position
number: 0,
userDataIndex: USER_DATA_INDEX,
Console.WriteLine("Axis moving... waiting for input trigger to E-Stop");
// wait for user limit to trigger
while (controller.InterruptWait(250) != RSIEventType.RSIEventTypeUSER_LIMIT)
// simulate input trigger
// wait for motion to stop
// get the stored position data
int triggeredUserLimit = controller.InterruptSourceNumberGet() - initialAxisCount; // account for extra user limit per axis
double interruptPosition = controller.InterruptUserDataDoubleGet(USER_DATA_INDEX);
double positionInUserUnits = interruptPosition / axis.UserUnitsGet();
Console.WriteLine($"✓ User limit triggered - E-Stop executed");
Console.WriteLine($" Triggered User Limit: {triggeredUserLimit}");
Console.WriteLine($" Position at trigger: {positionInUserUnits} (user units)");
axis.Abort();
Console.WriteLine("\nUser limit E-Stop store position complete.");
double UserUnitsGet()
Definition rsi.h:12981
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Definition rsienums.h:451
Trigger types for UserLimits.
Definition rsienums.h:758
