mathblock-difference-of-position-userlimit.cs
See IO: Math Blocks 📜 for a detailed explanation of this sample code.
/* This sample app demonstrates configuring a MathBlock to calculate the difference of position between two axes
and using that MathBlock process value in a UserLimit to trigger an abort action when the difference exceeds a threshold.
This sample app requires at least 2 Axis so that positions can be read.
Console.WriteLine("📜 MathBlock: Difference of Position UserLimit");
const int INDEX_ZERO = 0;
const RSIDataType DOUBLE = RSIDataType.RSIDataTypeDOUBLE;
const RSIMathBlockOperation SUBTRACT = RSIMathBlockOperation.RSIMathBlockOperationSUBTRACT;
// get rmp controller
// set mathblock & userlimit counts before any RapidCodeObject get/create other than the controller
controller.MathBlockCountSet(1);
controller.UserLimitCountSet(1);
// get & configure both axes
Helpers.CheckErrors(axis0);
Helpers.CheckErrors(axis1);
// set sample addresses
ulong axis0PositionAddr = axis0.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION);
ulong axis1PositionAddr = axis1.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION);
ulong mbProcessValueAddr = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, INDEX_ZERO);
// MathBlock config & set (mb.value = axis0.position - axis1.position)
var mbConfig = controller.MathBlockConfigGet(INDEX_ZERO);
mbConfig.Operation = SUBTRACT;
mbConfig.InputAddress0 = axis0PositionAddr; // input0: axis0 command position
mbConfig.InputAddress1 = axis1PositionAddr; // input1: axis1 command position
mbConfig.InputDataType0 = DOUBLE;
mbConfig.InputDataType1 = DOUBLE;
mbConfig.ProcessDataType = DOUBLE;
controller.MathBlockConfigSet(INDEX_ZERO, mbConfig);
// wait 1 sample for MathBlock config to take effect
controller.SampleWait(1);
// set UserLimit condition to trigger when absolute position difference exceeds threshold
number: INDEX_ZERO,
conditionNumber: 0,
logic: RSIUserLimitLogic.RSIUserLimitLogicABS_GT,
addressOfDouble: mbProcessValueAddr,
limitValueDouble: 5 * axis0.UserUnitsGet()); // 5 revolutions (values in firmware are not scaled by user units)
// set UserLimit to abort when condition above is met
number: INDEX_ZERO,
action: RSIAction.RSIActionABORT,
actionAxis: Constants.AXIS_0_INDEX,
duration: 0);
// move axis0 to trigger the UserLimit
axis0.MoveRelative(
relativePosition: 10, // revolutions
vel: 1,
accel: 1,
decel: 1,
jerkPct: 0);
axis0.MotionDoneWait();
// get results
var axis0State = axis0.StateGet();
// print results
Console.WriteLine($"Axis 0 state: {axis0State} (expected: {RSIState.RSIStateERROR})");
// verify userlimit triggered abort action
if (axis0State != RSIState.RSIStateERROR)
throw new Exception("❌ UserLimit did not trigger correctly - both axes should be in error state.");
Helpers.AbortMotionObject(axis0);
Helpers.AbortMotionObject(axis1);
controller.UserLimitDisable(INDEX_ZERO); // disable user limit
const int AXIS_1_INDEX
Definition _constants.cs:21
double UserUnitsGet()
RSIState StateGet()
MathBlock operations.
Definition rsienums.h:1614
RSIDataType
Definition rsienums.h:784
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Definition rsienums.h:451
Trigger types for UserLimits.
Definition rsienums.h:758
