PVTmotionMultiAxis.cpp
#include "SampleApps.h"
int PVTmotionMultiAxis::Run()
/* CONSTANTS */
const int AXIS_COUNT = 2;
const int AXIS_X = 0;
const int AXIS_Y = 1;
// Motion parameters
const int POINTS = (3000); //total points used
const double TIME_SLICE = (0.001); //each point processed within 1ms
USE_HARDWARE = false;
const char rmpPath[] = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)
/* SAMPLE APP BODY */
MotionController *controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
if (USE_HARDWARE)
multiAxisXY->AxisAdd(axisX);
multiAxisXY->AxisAdd(axisY);
long radius = 3; //radius of circle
double PI = 3.14159265358979323; //variable used in equation to convert degrees to radians
double degrees = 90.00 / (POINTS); //angle between each point. Used in the equation below.
double position[POINTS * AXIS_COUNT]; //defining size of position array
double vel[POINTS * AXIS_COUNT]; //defining size of velocity array
double time[POINTS]; //defining size of time array
for (int i = 0, x = 0, y = 1; i < POINTS; i++)
position[x] = (radius*cos((i + 1)*degrees*PI / 180.0));
position[y] = (radius*sin((i + 1)*degrees*PI / 180.0));
x = x + 2;
y = y + 2;
time[i] = TIME_SLICE;
for (int i = 0, x = 0, y = 1; i < (POINTS - 1); i++)
vel[x] = (position[x + 2] - position[x]) / TIME_SLICE;
vel[y] = (position[y + 2] - position[y]) / TIME_SLICE;
x = x + 2;
y = y + 2;
//Final two points (X Axis Final Vel, Y Axis Final Vel) need to be set to 0.
vel[(POINTS * 2) - 2] = 0; //X Axis
vel[(POINTS * 2) - 1] = 0; //Y Axis
// Set the initial position of the axes.
axisX->PositionSet(radius);
axisY->PositionSet(0);
multiAxisXY->Abort();
multiAxisXY->ClearFaults();
multiAxisXY->MovePVT(position, vel, time, POINTS, -1, false, true);
catch (RsiError const& err)
printf("\n%s\n", err.text);
return -1;
return 0;
void AxisAdd(Axis *axis)
Definition rsi.h:12226
Definition rsi.h:111
@ RSIActionNONE
Definition rsienums.h:1257
