phantom-axis.cpp
/* This sample app demonstrates how to create and configure phantom axes
that can be used for virtual axis operations.
int main()
const std::string SAMPLE_APP_NAME = "📜 Axis: Phantom Axis";
/* CONSTANTS */
const int NUM_AXES = 1; // the number of axes to configure, default is 0 for this template
// create the controller
// set the exit code to an error value.
int exitCode = -1;
// normally you would set the number of axes here, but for samples that is handled in the Config::SetupController function
/* SAMPLE APP BODY */
// get the axis
// configure the axis as a phantom axis
// these limits are not meaningful for a Phantom Axis (e.g., a phantom axis has no actual position so a position error trigger is not necessary)
// therefore, you must set all of their actions to "NONE".
// reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
const double positionToleranceMax = std::numeric_limits<double>::max() / 10.0;
axis->PositionToleranceCoarseSet(positionToleranceMax); // set Settling Coarse Position Tolerance to max value
// set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
axis->PositionToleranceFineSet(positionToleranceMax);
std::cout << "Phantom Axis created with index: " << AXIS_INDEX << std::endl;
exitCode = 0; // Set the exit code to success.
exitCode = -1;
Config::Cleanup(controller);
controller->Delete();
Set the Amp Fault action.
Set the motor type.
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIMotorTypePHANTOM
Definition rsienums.h:1455
Definition config.h:147
Definition config.h:81
[SetupController]
Definition config.h:206
Definition helpers.h:87
[NetworkShutdown]
Definition helpers.h:205
[PrintHeader]
Definition helpers.h:221
Definition rsi.h:872
