axis-motion-streaming-pvt.cs
See Motion: Streaming 📜 for a detailed explanation of this sample code.
/* Demonstrates PVT (Position-Velocity-Time) streaming motion.
PVT motion requires position, velocity, and time arrays.
The controller calculates acceleration for each segment.
Console.WriteLine("📜 Axis Streaming Motion: PVT");
// configure phantom axis
double[] velocities = [12.0, 10.0, 6.0]; // velocities for each position
double[] times = [0.1, 0.2, 0.1]; // time deltas (acceleration calculated by RMP)
axis.MovePVT(positions, // positions to reach
times, // time deltas
true); // if this is the last MovePVT call (true = final point, false = more points expected)
