using System.Threading;
Console.WriteLine("📜 Motion: G-Code");
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 4, minRequiredSampleMultiAxisCount: 1);
string gcodeProgram = @"G91; Sets the programming mode to RELATIVE
G64; Turns off exact stop mode (Default)
G1 X1.0 Y0.0 Z0.0 A1.0 F60.0; Move on USERUNIT in positive x direction at 60in/min. Moves Free axis A to position 1.0.
G3 X1 Y1 I0 J1; Counter clockwise arc with a center point of 0,1,0 and end point of 1,1,0 relative to the current position
M80; Show how to use an M-code with GcodeCallback!";
int multiAxisMotionSupervisorIndex = controller.AxisCountGet();
Axis[] axes = [xAxis, yAxis, zAxis, aAxis];
jointsMultiAxis.
AxesAdd(axes, axes.Length);
const double scaling = 1.0;
const double offset = 0.0;
builder.FreeAxisAdd(new ModelAxisMapping(3) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
robot.Gcode.AccelerationRateSet(1000);
robot.Gcode.FreeAxisLetterSet(gcodeLetter: 'A', freeAxisIndex: 0);
SampleGcodeCallback callback = new();
robot.Gcode.CallbackRegister(callback, reloadAfterCallback: false);
robot.Gcode.Load(gcodeProgram);
Console.WriteLine($"Error loading G-Code: {e.Message}");
throw;
Console.WriteLine($"G-Code Line Count: {robot.Gcode.LineCountGet()}");
Console.WriteLine($"G-Code Error Log Count: {robot.Gcode.ErrorLogCountGet()}");
Console.WriteLine($"G-code estimated run time: {robot.Gcode.DurationGet()} seconds");
robot.Gcode.Run();
Int64 activeLineNumber = 0;
do
Thread.Sleep(20);
if (activeLineNumber != robot.Gcode.ExecutingLineNumberGet())
activeLineNumber = robot.Gcode.ExecutingLineNumberGet();
Console.WriteLine($"G-Code Line Number: {activeLineNumber}");
} while (robot.Gcode.IsRunning());
if (robot.Gcode.IsRunning())
robot.Gcode.Cancel();
robot.Gcode.CallbackRegister(null, reloadAfterCallback: false);
GC.KeepAlive(callback);
Console.WriteLine("✅ G-Code motion completed successfully");
controller.Delete();
public class SampleGcodeCallback : GcodeCallback
public override void Execute(GcodeCallbackData data)
Console.WriteLine("G-Code Callback executed: " + data.LineNumber + " " + data.LineText);
const int AXIS_3_INDEX
Default: 3.
const int AXIS_1_INDEX
const int AXIS_2_INDEX
Default: 2.
void AxisRemoveAll()
