| class | Axis |
| | Represents a single axis of motion control. This class provides an interface for commanding motion, reading trajectory parameters, homing, limit switch configuration, motor configuration, position capture, configuring filter (control law) parameters, electronic gearing and access to its NetworkNode. Get or create an Axis object using MotionController::AxisGet. More...
| union | FirmwareValue |
| | Union representing a generic RMP firmware value with multiple data types, stored in 64-bits. More...
| class | IOPoint |
| | Represents one specific point: Digital Output, Digital Input, Analog Output, or Analog Input. This class provides a helper interface to any I/O, regardless of where it resides: MotionController, Axis, or NetworkNode. To create an IOPoint, use IOPoint Creation Methods. More...
| class | MotionController |
| | Represents the RMP soft motion controller. This class provides an interface to general controller configuration, firmware upload/download, network, user limits and data recording. To make a MotionController object, use MotionController creation methods.. More...
| class | MultiAxis |
| | Represents multiple axes of motion control, allows you to map two or more Axis objects together for error propagation and commanding coordinated, synchronized motion. Create a MultiAxis object on the controller and get it using MotionController::LoadExistingMultiAxis. More...
| class | NetworkNode |
| | Represents an EtherCAT node / SubDevice (Drive, I/O Block, etc) on the network. This class provides an interface to all digital and analog I/O on the node, as well as the ability to read and write SDOs. Get or create a NetworkNode using MotionController::NetworkNodeGet or the Axis property, NetworkNode. More...
| class | RapidCodeInterrupt |
| | Interface for objects which can use interrupts. More...
| class | RapidCodeMotion |
| | The RapidCodeMotion interface is implemented by Axis and MultiAxis . More...
| class | RapidCodeObject |
| | The RapidCode base class. All non-error objects are derived from this class. More...
| class | RapidCodeOS |
| | The RapidCodeOS object provides access to operating system (Windows) features. Accessible via MotionController . More...
| class | RapidVector< Type > |
| | A wrapper class for the C++ STL vector class that aims to maintain application binary interface. Provides some of the basic vector operations (with RapidCode naming conventions). More...
| class | RsiError |
| | Represents the error details thrown as an exception by all RapidCode classes. This class contains an error number/type, RSIErrorMessage, and a text message which describes the error. Throwing exceptions can be disabled on all RSI classes. If throwing exceptions is disabled, a log of RsiErrors can be accessed. Inherits from std::exception in C++ and System.Exception in C#. More...
| class | RTOS |
| | Represents the real-time operating system (INtime) when using RMP for Windows. This class provides static methods to start, stop, and restart INtime. More...
| class | Trace |
| | Tracing allows for low level logs to be generated. More...
