axis-motion-hold-via-digitalinput.cs
See Motion: Hold 📜 for a detailed explanation of this sample code.
// configure axis
// enable motion hold
axis.MoveRelative(3);
// disable motion hold
Set the motion hold type.
Definition rsienums.h:621
RSIMotionAttrMask
Definition rsienums.h:1201
RSIMotionHoldType
Definition rsienums.h:1236
