axis-motion-modify.cs
See Motion: Modify 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to modify motion in-flight using feed rate and velocity changes.
Shows how to use FeedRate to adjust speed, reverse motion, and change velocity mid-motion.
using System.Threading;
Console.WriteLine("📜 Axis Motion: Modify");
const double POSITION = 10;
const double VELOCITY = 3;
const double ACCELERATION = 10;
const double DECELERATION = 10;
// configure phantom axis
│ FEED RATE │
Console.WriteLine("\n1. Feed Rate");
// start motion
Console.WriteLine($"\tPosition commanded: {POSITION}");
// set feedrate to 150%
axis.FeedRateSet(1.5);
// wait here until we reach position 5
while (axis.CommandPositionGet() < 5)
Thread.Sleep(10);
// stop motion
axis.Stop();
axis.MotionDoneWait();
Console.WriteLine($"\tPosition after FeedRate (1.5): {axis.CommandPositionGet()}");
// set feedrate to reverse motion (-100%)
axis.FeedRateSet(-1);
// resume motion for a bit
axis.Resume();
Thread.Sleep(500);
Console.WriteLine($"\tPosition after FeedRate (-1): {axis.CommandPositionGet()}");
// restore feedrate (100%)
axis.FeedRateSet(1);
// wait for motion done
Console.WriteLine($"\tPosition after FeedRate (1): {axis.CommandPositionGet()} (expected: {POSITION})");
if (!Constants.USE_HARDWARE) Helpers.PhantomAxisReset(axis); // reset
axis.PositionSet(0); // reset position
│ CHANGE MOTION SPEED │
Console.WriteLine("\n2. Change Motion Speed");
// start motion
// wait until position > 5
Thread.Sleep(10);
Console.WriteLine($"\tPosition before speed change: {axis.CommandPositionGet()}");
// modify motion to go 10x faster
axis.MoveSCurve(POSITION, VELOCITY * 10, ACCELERATION, DECELERATION, JERK_PERCENT);
Console.WriteLine($"\tFinal position: {axis.CommandPositionGet()} (expected: {POSITION})");
double CommandPositionGet()
void Resume()
Resume an axis.
void FeedRateSet(double rate)
