config.h
#ifndef CONFIG_H
#define CONFIG_H
// These macros are defined as part of the build process in CMake. To avoid
// build errors, we default them to empty strings if they are not defined.
#ifndef RMP_INSTALL_PATH
#define RMP_INSTALL_PATH ""
#endif
#include <sstream>
#include <source_location>
#include "helpers.h"
using namespace RSI::RapidCode; // Import our RapidCode namespace
namespace Config
// Motion Controller Creation Parameters
inline constexpr char RMP_PATH[] = RMP_INSTALL_PATH;
inline constexpr char NIC_PRIMARY[] = "";
inline constexpr char NODE_NAME[] = "";
inline constexpr int CPU_AFFINITY = 0;
// If you want to use hardware, then follow the instructions in the README before setting this to true.
inline constexpr bool USE_HARDWARE = false;
// If you have configured your axes using rsiconfig, RapidSetup, or RapidSetupX then you can comment out this error and return.
// IMPLEMENTATION REQUIRED: Configure the axes for hardware
std::ostringstream message;
message << "You must implement the " << __func__ << " function (found in " << __FILE__ << " line " << __LINE__ << ") to use hardware.";
// Simple Axis Configuration Example:
// (Look at the Axis: Configuration section in the RapidCode API Reference for more advanced configurations)
// const int USER_UNITS = 1048576; // example for 20-bit encoder, 2^20 = 1048576
// Axis *axis = controller->AxisGet(0);
// Helpers::CheckErrors(axis);
// axis->UserUnitsSet(USER_UNITS);
// axis->PositionSet(0);
// axis->ErrorLimitTriggerValueSet(0.1 * USER_UNITS);
// axis->ErrorLimitActionSet(RSIAction::RSIActionABORT);
// axis->Abort();
// axis->ClearFaults();
#if _WIN32
// Create a controller with using defined parameters
strncpy(params.RmpPath, RMP_PATH, params.PathLengthMaximum);
strncpy(params.NicPrimary, NIC_PRIMARY, params.PathLengthMaximum);
strncpy(params.NodeName, NODE_NAME, params.PathLengthMaximum);
return params;
#elif __linux__
return params;
#endif
void ConfigurePhantomAxis(MotionController *controller, int axisIndex)
// Check that the axis has been initialized correctly
Axis* axis = controller->AxisGet(axisIndex);
10.0; // Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
axis->PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
axis->PositionToleranceFineSet(positionToleranceMax
); // Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
static int initialAxisCount = -1;
static int initialMotionCount = -1;
void SetupController(MotionController *controller, int numAxes = 0)
// Start or shutdown the network depending on the configuration
Helpers::NetworkStart(controller);
else if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
controller->NetworkStateGet() != RSINetworkState::RSINetworkStateSHUTDOWN)
message << "The Sample Apps are configured to use Phantom Axes, but the network is not in the UNINITIALIZED or SHUTDOWN state.\n"
<< "If you intended to run with hardware, then follow the steps in README.md and /src/config.h\n"
<< "Otherwise, shutdown the network before running the sample apps with phantom axes.";
// Check if we are using hardware or phantom axes
// Let the user defined function configure the axes
ConfigureHardwareAxes(controller);
// Check that there are enough axes configured
int axisCount = controller->AxisCountGet();
if (axisCount < numAxes)
message << "Error! Not enough axes configured. Expected " << numAxes << " axes but only found " << axisCount << " axes."
<< "Please configure the axes in the Config::ConfigureHardwareAxes function.";
// Record the initial object counts to restore later
initialAxisCount = controller->AxisCountGet();
initialMotionCount = controller->MotionCountGet();
// Add phantom axes for the sample app if needed
if (numAxes > initialAxisCount)
controller->AxisCountSet(numAxes);
for (int i = 0; i < numAxes; i++)
ConfigurePhantomAxis(controller, i);
void Cleanup(MotionController* controller)
if (initialAxisCount != -1) { controller->AxisCountSet(initialAxisCount); }
if (initialMotionCount != -1) { controller->MotionCountSet(initialMotionCount); }
// Reset the object counts
#endif // CONFIG_H
Set the Amp Fault action.
Set the motor type.
@ RSINetworkStateSHUTDOWN
Definition rsienums.h:628
EtherCAT not yet started.
Definition rsienums.h:622
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIMotorTypePHANTOM
Definition rsienums.h:1455
[ConfigurePhantomAxis]
Definition config.h:139
Definition config.h:147
Definition config.h:81
[GetCreationParameters]
Definition config.h:110
Path to the RMP.rta file (usually the RapidSetup folder).
Definition config.h:34
[SetupController]
Definition config.h:206
void ConfigureHardwareAxes(MotionController *controller)
Configures the hardware axes according to user specified implementation.
Definition config.h:47
This namespace provides static methods and constants for user configuration in RMP applications....
Definition config.h:25
(Linux only) CPU core to use. This should be an isolated core.
Definition config.h:37
Initial motion count to restore later (-1 indicates it has not been set).
Definition config.h:140
Name of the NIC to use for the EtherCAT network (not needed for running on phantom axes).
Definition config.h:35
Definition config.h:40
(Windows only) INtime node name. Use "" for default node.
Definition config.h:36
Definition helpers.h:87
[CheckErrors]
Definition helpers.h:128
char NodeName[PathLengthMaximum]
[Windows/INtime] Indicate the INtime node on which the RMP and RMPNetwork processes run.
Definition rsi.h:1045
Definition rsi.h:978
int32_t CpuAffinity
Definition rsi.h:1065
char NicPrimary[PathLengthMaximum]
Primary EtherCAT Network Interface (NIC) name.
Definition rsi.h:1019
Definition rsi.h:888
Definition rsi.h:872
