PhantomAxis.cpp
Attention
See the following Concept pages for a detailed explanation of this sample: Phantom Axes.
int main()
const std::string SAMPLE_APP_NAME = "Axis Configuration: Phantom Axis";
/* CONSTANTS */
const int NUM_AXES = 1; // The number of axes to configure, default is 0 for this template
const int AXIS_INDEX = 0; // The index of the axis to configure
// Create the controller
int exitCode = -1;
// Prepare the controller as defined in SampleAppsHelper.h depending on the configuration
SampleAppsHelper::SetupController(controller, NUM_AXES);
// Normally you would set the number of axes here, but for samples that is handled in the SampleAppsHelper::SetupController function
/* SAMPLE APP BODY */
// Get the axis
// Configure the axis as a phantom axis
// Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
const double positionToleranceMax = std::numeric_limits<double>::max() / 10.0;
axis->PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
// Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
axis->PositionToleranceFineSet(positionToleranceMax);
std::cout << "Phantom Axis created with index: " << AXIS_INDEX << std::endl;
exitCode = 0; // Set the exit code to success.
exitCode = -1;
// Clean up the controller and any other objects as needed
controller->Delete();
Set the Amp Fault action.
Set the motor type.
Definition rsi.h:5863
Definition rsi.h:800
@ RSIActionNONE
Definition rsienums.h:1116
@ RSIMotorTypePHANTOM
Definition rsienums.h:1314
Definition rsi.h:866
