GcodeMotion.cs
Attention
See the following Concept pages for a detailed explanation of this sample: G-Code.
using NUnit.Framework;
using System;
using System.Linq;
using System.Threading;
using System.IO;
using System.Runtime.InteropServices;
#endif
public override void Execute(GcodeCallbackData data)
Console.WriteLine("G-Code Callback executed: " + data.LineNumber + " " + data.LineText);
// if you want to nofity the Gcode object that there's an error processing, set its error details:
// data.UserError.number = RSIErrorMessage.RSI_ERROR_MESSAGE_DYNAMIC;
// data.UserError.text = "This is an error from the callback.";
[TestFixture]
[Category("Software")]
public class GcodeMotion : SampleAppTestBase
[SetUp]
public void Setup()
jointsMultiAxis?.AxisRemoveAll();
[TearDown]
public void Teardown()
robot?.EStop();
robot?.MotionDoneWait();
robot?.ClearFaults();
robot = null;
jointsMultiAxis?.Abort();
Thread.Sleep(50);
jointsMultiAxis?.ClearFaults();
private void VerifyModel(KinematicModel model, string expectedName, LinearUnits expectedUnits = LinearUnits.None)
var actualUnits = model.UnitsGet();
Assert.That(actualUnits, Is.EqualTo(expectedUnits), $"Expected model units to be '{expectedUnits}' but was '{actualUnits}' instead!");
var actualName = model.NameGet();
Assert.That(actualName, Is.EqualTo(expectedName), $"Expected model name to be '{expectedName}' but was '{actualName}' instead!");
[Test]
public void GcodeBasic()
string gcodeProgram = "G91; Sets the programming mode to RELATIVE\n" +
"G64; Turns off exact stop mode(Default)\n" +
"G1 X1.0 Y0.0 Z0.0 A1.0 F60.0; Move on USERUNIT in positive x direction at 60in/min. Moves Free axis A to position 1.0.\n" +
"G3 X1 Y1 I0 J1; Counter clockwise arc with a center point of 0,1,0 and end point of 1,1,0 relative to the current position\n" +
"M80; Show how to use an M-code with GcodeCallback!\n";
// We assume the axes have been confgured and homed properly prior this this program.
x_axis.UserLabelSet(xLabel);
y_axis.UserLabelSet(yLabel);
z_axis.UserLabelSet(zLabel);
a_axis.UserLabelSet(aLabel);
// The joint index of each axis is the index within the MultiAxis object.
// "X-Axis" has joint index 0
// "Y-Axis" has joint index 1
// "Z-Axis" has joint index 2
// "A-Axis" has joint index 3
Axis[] axes = new Axis[] { x_axis, y_axis, z_axis, a_axis };
jointsMultiAxis.AmpEnableSet(true);
LinearModelBuilder builder = new LinearModelBuilder(modelName);
builder.FreeAxisAdd(new ModelAxisMapping(3) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset }); // Add a free axis.
// Create a Robot object with a multi axis containing all joints and the kinematic type
robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, MotionController.AxisFrameBufferSizeDefault);
robot.Gcode.AccelerationRateSet(1000); // UserUnits per minute squared
// The free axis index here refers to the index in the RobotPosition freeAxes array. We use index 0 here to refer to the first position in that array.
robot.Gcode.FreeAxisLetterSet('A', 0);
robot.Gcode.CallbackRegister(callback); // Register a callback to be called when the Gcode encounters any M-code command
robot.Gcode.Load(gcodeProgram); // Loads in the string and prepairs it for execution
Console.WriteLine("Error loading G-Code: " + e.Message);
// get any additional G-Code errors (will give you details of every line number that has an error in parsing or processing)
throw e; // exit the program
// print some details about the upcoming motion
Console.WriteLine("G-Code Line Count: " + robot.Gcode.LineCountGet());
Console.WriteLine("G-Code Error Log Count: " + robot.Gcode.ErrorLogCountGet());
Console.WriteLine("G-code estimated run time: " + robot.Gcode.DurationGet() + " seconds");
robot.Gcode.Run(); // Starts the motion. Calling with the false arguement for non blocking behavior
Int64 activeLineNumber = 0;
do
Thread.Sleep(200);
if (activeLineNumber != robot.Gcode.ExecutingLineNumberGet()) // only write if we are on a new line
activeLineNumber = robot.Gcode.ExecutingLineNumberGet();
Console.WriteLine("G-Code Line Number: " + activeLineNumber);
} while (robot.Gcode.IsRunning());
HelperFunctions.CheckErrors(robot.Gcode); // Check for any errors that may have occured during the motion
Assert.That(robot.Gcode.ErrorLogCountGet(), Is.EqualTo(0), "Gcode Error Log Count is not zero. first error: " + robot.Gcode.ErrorLogGet().Message);
Assert.That(robot.Gcode.LineCountGet(), Is.EqualTo(gcodeProgram.Count(c => c.Equals('\n'))));
VerifyModel(robot.ModelGet(), modelName);
[Test]
public void ChangingUnits()
b_axis.UserLabelSet(bLabel);
c_axis.UserLabelSet(cLabel);
// "B-Axis" has joint index 4
// "C-Axis" has joint index 5
Axis[] axes = new Axis[] { x_axis, y_axis, z_axis, a_axis, b_axis, c_axis };
const string modelName = "RSI_XYZABC_Centimeters";
const LinearUnits units = LinearUnits.Centimeters;
builder.UnitsSet(units);
builder.JointAdd(new LinearJointMapping(3, CartesianAxis.Roll) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(new LinearJointMapping(4, CartesianAxis.Pitch) { ExpectedLabel = bLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(new LinearJointMapping(5, CartesianAxis.Yaw) { ExpectedLabel = cLabel, Scaling = scaling, Offset = offset });
//NOTE: to use the above kinematic model you must have a gantry (linear 1:1 kinematics) and each linear axis must have its user units scaled to millimeters
//This will return none. A gcode unit hasn't been established to it will use path units. If path units are not set it will use user units.
Console.WriteLine(robot.Gcode.UnitsGet());
robot.Gcode.AccelerationRateSet(10); //Sets the G-Code acceleration to 10 Centimeters(USER UNITS) per MINUTE sqd
robot.Gcode.FeedRateSet(10); //Sets the G-Code velocity to 10 Centimeters(USER UNITS) per MINUTE
robot.Gcode.UnitsSet(LinearUnits.Inches);//This is the same as executing the G-Code Line G20
Console.WriteLine(robot.Gcode.UnitsGet());//This will return Inches as you just set.
robot.Gcode.AccelerationRateSet(10); //Sets the G-Code acceleration to 10 Inches per MINUTE sqd
robot.Gcode.FeedRateSet(10); //Sets the G-Code velocity to 10 Inches per MINUTE
VerifyModel(robot.ModelGet(), modelName, units);
Definition rsi.h:5870
void FreeAxisLetterSet(const char gcodeLetter, const int32_t freeAxisIndex)=0
Map a letter in a Gcode file to a free axis. It will be used to specify the free axis' motion.
void CallbackRegister(Cartesian::GcodeCallback *callback, bool containsMotion=false)=0
G-code callback register.
int32_t LineCountGet()=0
Get the number of lines in the last loaded G-Code program.
int32_t ExecutingLineNumberGet()=0
Get the currently executing line number.
LinearUnits UnitsGet()=0
Get the currently active unit as set by G20/G21.
void AccelerationRateSet(double programmingUnitsPerMinuteSquared)=0
REQUIRED before Load() or LoadFile(). Sets the target acceleration for the machine (units/minute^2)....
void UnitsSet(LinearUnits units)=0
Set the currently active unit (same as calling G20/G21)
double DurationGet()=0
Get the time duration required to run the loaded G-Code program in seconds.
void FeedRateSet(double programmingUnitsPerMinute)=0
REQUIRED before Load() or LoadFile() if your g-code does not have 'F' in its contents....
void Load(const char *const text)=0
Load a G-code program from a string.
void Run()=0
Run the loaded G-Code file (or string). The behavior is non-blocking. Use DoneWait() to block.
Handles callbacks for M-codes within a G-code file.
bool IsRunning()=0
Returns true if a Gcode program is executing, false otherwise.
void FreeAxisAdd(const ModelAxisMapping &freeAxis)
Map a free axis in the kinematic model. The Axis' DefaultVelocity/Acceleration will be used for free ...
uint64_t MotionDoneWait()=0
void EStop()=0
void ClearFaults()=0
Delete a Robot.
RSI::RapidCode::Cartesian::Gcode * Gcode
An object to load and run Gcode files.
Definition rsi.h:854
Definition rsi.h:800
void AxisRemoveAll()
int32_t ErrorLogCountGet()
make a Callback class and register it with the Gcode object
CartesianAxis
LinearUnits
The Cartesian namespace.
const char * LineText
The actual line content from the G-code file.
int32_t LineNumber
The line number in the G-code file where the M-code is encountered.
Holds data for the G-code M-code callback mechanism.
Data for adding joint or free-axis mappings when building a kinematic model.
