◆ AmpEnableSet() [1/2]
void AmpEnableSet ( bool enable)
AmpEnableSet enables (or disables) all amplifiers.
enabletrue = enable all, false = disable all.
AmpEnableSet(true) does not wait for the amp to become fully enabled. Use the AmpEnableSet(bool, int32_t) overload to wait for the amp to become fully enabled.
Attention
For DS402 axes, the RMP firmware will automatically generate an Amp Fault action (default is to Abort) if the AMP_ACTIVE signal does not got high within one second of AmpEnableSet(true). If it fails to enable, the Axis will end in an ERROR state. This value is configurable using RSIAxisAddressType::RSIAxisAddressTypeAMP_ENABLE_AMP_FAULT_TIMEOUT with MotionController::MemoryDoubleGet() and MotionController::MemoryDoubleSet(). The default value is Axis::AmpEnableAmpFaultTimeoutSecondsDefault.
ConfigAmpFault
public void EnableAmp(Axis myAxis)
myAxis.ClearFaults(); // To enable after an abort faults must be cleared.
myAxis.AmpEnableSet(true); // Enable the motor.
Go to axis screen->Axis Status.
Left: Amp Enabled, Right: Amp Disabled
ClearFaults, RSIAxisAddressType::RSIAxisAddressTypeAMP_ENABLE_AMP_FAULT_TIMEOUT
AxisConfig.cs, AxisConfiguration.cpp, CalculateAccelerationFromVelocity.cpp, DifferenceOfPositionUserLimit.cpp, GcodeMotion.cs, HelperFunctions.cs, Homing.cs, InputOutput.cs, MathBlock.cs, MotionHoldReleasedBySoftwareAddress.cpp, MultiAxisMotion.cs, MultiaxisMotion.cpp, PVTmotionMultiAxis.cpp, PathMotion.cpp, PathMotion.cs, PointToPoint.cpp, RandomWalk.cpp, SingleAxisSyncOutputs.cpp, SyncOutputWithMotion.cpp, Template.cs, UpdateBufferPoints.cpp, UserLimit.cs, UserLimitCommandPositionDirect.cs, and VelocitySetByAnalogInputValue.cs.
