MathBlock.cs
Attention
See the following Concept pages for a detailed explanation of this sample: Math Blocks.
using RSI.RapidCode.dotNET; // the RapidCode.NET library.
using System;
#endif
public class MathBlockDifferenceOfPositionUserLimit : SampleApp
public override int Run()
/* CONSTANTS */
// Controller Object Counts
const int MATHBLOCK_COUNT = 1; // minimum required MathBlocks for this sample
const int AXIS_COUNT = 2; // minimum required axes for this sample
const int USER_LIMIT_COUNT = 1; // minimum required user limits for this sample
// Axis Configuration
const int FIRST_AXIS_INDEX = 0; // the first axis index
const int SECOND_AXIS_INDEX = 1; // the second axis index
const double USER_UNITS = 1048576; // counts per unit (the user units)
// MathBlock Configuration
const int MATHBLOCK_INDEX = 0; // the mathblock index
// User Limit Configuration
const int USER_LIMIT_INDEX = 0; // the user limit index
const double MAX_POSITION_DIFFERENCE = 0.5 * USER_UNITS; // the maximum position difference before the user limit triggers
const RSIAction USER_LIMIT_ACTION = RSIAction.RSIActionABORT; // the action to take when the user limit is triggered
const int USER_LIMIT_DURATION = 0; // the time delay before the action is executed after the User Limit has triggered
// Motion Parameters
const double RELATIVE_POSITION = 2 * MAX_POSITION_DIFFERENCE; // the relative position to move the axes
const double VELOCITY = 1; // the velocity to move the axes
const double ACCELERATION = 10; // the acceleration of the axes movement
const double DECELERATION = 10; // the deceleration of the axes movement
const double JERK_PCT = 0; // the jerk percentage of the axes movement
USE_HARDWARE = false;
// Determine which axis address type to use based on the USE_HARDWARE flag
RSIAxisAddressType INPUT_AXIS_ADDRESS_TYPE = (USE_HARDWARE) ?
(RSIAxisAddressType.RSIAxisAddressTypeACTUAL_POSITION) : (RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION);
/* SAMPLE APP BODY */
// NOTICE: Replace "rmpPath" with the path location of the RMP.rta (usually the RapidSetup folder)
// if project directory is different than rapid setup directory.
// Use a try/catch/finally to ensure that the controller is deleted when done.
HelperFunctionsCS.CheckErrors(controller); // [Helper Function] Check that the axis has been initialize correctly.
if (USE_HARDWARE)
HelperFunctionsCS.SetupControllerForPhantoms(controller, AXIS_COUNT, new int[] { FIRST_AXIS_INDEX, SECOND_AXIS_INDEX });
// configure the controller object counts
controller.MathBlockCountSet(MATHBLOCK_COUNT);
controller.MotionCountSet(AXIS_COUNT + 1);
// get both axis objects and check for errors
Axis axis0 = controller.AxisGet(FIRST_AXIS_INDEX);
axis0.UserUnitsSet(USER_UNITS); // set the user units (counts per unit)
axis0.PositionSet(0); // set the initial position to 0
axis0.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Set Error Limit Action.
Axis axis1 = controller.AxisGet(SECOND_AXIS_INDEX);
axis1.UserUnitsSet(USER_UNITS); // set the user units (counts per unit)
axis1.PositionSet(0); // set the initial position to 0
axis1.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Set Error Limit Action.
// configure a multiaxis for the two axes
MultiAxis multiAxis = controller.MultiAxisGet(AXIS_COUNT);
multiAxis.AxisRemoveAll();
multiAxis.AxisAdd(axis0);
multiAxis.AxisAdd(axis1);
multiAxis.Abort(); // make sure the multiaxis is not moving
multiAxis.ClearFaults(); // clear any faults
// read the configuration of the MathBlock
MotionController.MathBlockConfig mathBlockConfig = controller.MathBlockConfigGet(MATHBLOCK_INDEX);
// configure the MathBlock to subtract the position of the second axis from the position of the first axis
mathBlockConfig.InputAddress0 = axis0.AddressGet(INPUT_AXIS_ADDRESS_TYPE);
mathBlockConfig.InputDataType0 = RSIDataType.RSIDataTypeDOUBLE;
mathBlockConfig.InputAddress1 = axis1.AddressGet(INPUT_AXIS_ADDRESS_TYPE);
mathBlockConfig.InputDataType1 = RSIDataType.RSIDataTypeDOUBLE;
mathBlockConfig.ProcessDataType = RSIDataType.RSIDataTypeDOUBLE;
mathBlockConfig.Operation = RSIMathBlockOperation.RSIMathBlockOperationSUBTRACT;
// set the MathBlock configuration
controller.MathBlockConfigSet(MATHBLOCK_INDEX, mathBlockConfig);
// wait a sample so we know the RMP is now processing the newly configured MathBlocks
controller.SampleWait(1);
Console.WriteLine("MathBlock configured to subtract the position of the second axis from the position of the first axis.");
// get the address of the MathBlock's ProcessValue to use in the UserLimit
ulong mathBlockProcessValueAddress = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, MATHBLOCK_INDEX);
// configure the UserLimit to trigger when the absolute position difference is greater than MAX_POSITION_DIFFERENCE
controller.UserLimitConditionSet(USER_LIMIT_INDEX, 0, RSIUserLimitLogic.RSIUserLimitLogicABS_GT, mathBlockProcessValueAddress, MAX_POSITION_DIFFERENCE);
// set the UserLimit action to abort motion (Note: since the axes are in a multiaxis, the other axis will also be aborted)
controller.UserLimitConfigSet(USER_LIMIT_INDEX, RSIUserLimitTriggerType.RSIUserLimitTriggerTypeSINGLE_CONDITION, USER_LIMIT_ACTION, FIRST_AXIS_INDEX, USER_LIMIT_DURATION);
Console.WriteLine("UserLimit configured to trigger when the absolute position difference is greater than " + MAX_POSITION_DIFFERENCE + " and abort motion.");
// command motion to trigger the UserLimit
Console.WriteLine("Moving the axes to trigger the UserLimit...");
axis0.AmpEnableSet(true); // Enable the motor.
axis0.MoveRelative(RELATIVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PCT); // Move the axis to trigger the UserLimit.
axis0.MotionDoneWait(); // Wait for the axis to finish moving.
// disable the motor and the UserLimit
axis0.AmpEnableSet(false); // Disable the motor.
controller.UserLimitDisable(USER_LIMIT_INDEX); // Disable User Limit.
// the motion should have been aborted and both axes should be in an error state
if (axis0.StateGet().Equals(RSIState.RSIStateERROR) &&
axis1.StateGet().Equals(RSIState.RSIStateERROR))
Console.WriteLine("Both axes are in the error state after the UserLimit triggered (This is the intended behavior).");
return 0;
Console.WriteLine("Error: The axes should be in an error state after the UserLimit triggers, but they are not.");
Console.WriteLine("First Axis State: " + axis0.StateGet());
Console.WriteLine("Second Axis State: " + axis1.StateGet());
return -1;
Console.WriteLine("Error: " + e.Message);
return -1;
controller.Delete(); // Delete the controller object.
public class MathBlockCalculateAccelerationFromVelocity : SampleApp
/* CONSTANTS */
const int MATHBLOCK_COUNT = 2; // minimum required MathBlocks for this sample
const int AXIS_COUNT = 1; // minimum required axes for this sample
const int AXIS_INDEX = 0; // the axis index
const int SUBTRACTION_MATHBLOCK_INDEX = 0; // the first mathblock index (for subtraction)
// the second mathblock index (for multiplying CommandVelocity * 1.0)
const int PREVIOUS_VELOCITY_MATHBLOCK_INDEX = 1; // index must be higher here than the subtraction math block index, so the subtraction data is one sample old
const double ONE = 1.0; // we'll write 1.0 to the UserBuffer so the MathBlock can use it for multiplication
const int USERBUFFER_INDEX = 0; // where we'll write 1.0 so the math block can use it
const double VELOCITY = 1.0; // the velocity to move the axis
const double ACCELERATION = 0.123; // something small so we can check the MathBlock is working
RSIAxisAddressType INPUT_AXIS_ADDRESS_TYPE = RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_VELOCITY;
if (USE_HARDWARE)
HelperFunctionsCS.SetupControllerForPhantoms(controller, AXIS_COUNT, new int[] { AXIS_INDEX });
// write 1.0 to the UserBuffer so the MathBlock can use it for multiplication
controller.MemoryDoubleSet(controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, USERBUFFER_INDEX), ONE);
// get Axis object and check for errors
Axis axis = controller.AxisGet(AXIS_INDEX);
axis.UserUnitsSet(USER_UNITS); // set the user units (counts per unit)
axis.PositionSet(0); // set the initial position to 0
axis.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Set Error Limit Action.
axis.Abort(); // make sure the axis is not moving
axis.ClearFaults(); // clear any faults
// read the configuration of both MathBlocks
MotionController.MathBlockConfig subtractionConfig = controller.MathBlockConfigGet(SUBTRACTION_MATHBLOCK_INDEX);
MotionController.MathBlockConfig previousVelocityConfig = controller.MathBlockConfigGet(PREVIOUS_VELOCITY_MATHBLOCK_INDEX);
// configure the first MathBlock to subtract the previous velocity from the current velocity
// current velocity:
subtractionConfig.InputAddress0 = axis.AddressGet(INPUT_AXIS_ADDRESS_TYPE);
subtractionConfig.InputDataType0 = RSIDataType.RSIDataTypeDOUBLE;
// previous velocity: (as was calculated by the second MathBlock, so we use its ProcesValue)
subtractionConfig.InputAddress1 = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, PREVIOUS_VELOCITY_MATHBLOCK_INDEX);
subtractionConfig.InputDataType1 = RSIDataType.RSIDataTypeDOUBLE;
subtractionConfig.ProcessDataType = RSIDataType.RSIDataTypeDOUBLE;
subtractionConfig.Operation = RSIMathBlockOperation.RSIMathBlockOperationSUBTRACT;
// configure the second MathBlock to multiply the current velocity by 1.0 (which we'll use for the previous sample's velocity)
previousVelocityConfig.InputAddress0 = axis.AddressGet(INPUT_AXIS_ADDRESS_TYPE);
previousVelocityConfig.InputDataType0 = RSIDataType.RSIDataTypeDOUBLE;
previousVelocityConfig.InputAddress1 = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, USERBUFFER_INDEX);
previousVelocityConfig.InputDataType1 = RSIDataType.RSIDataTypeDOUBLE;
previousVelocityConfig.ProcessDataType = RSIDataType.RSIDataTypeDOUBLE;
previousVelocityConfig.Operation = RSIMathBlockOperation.RSIMathBlockOperationMULTIPLY;
// set the MathBlock configurations
controller.MathBlockConfigSet(SUBTRACTION_MATHBLOCK_INDEX, subtractionConfig);
controller.MathBlockConfigSet(PREVIOUS_VELOCITY_MATHBLOCK_INDEX, previousVelocityConfig);
// Set the axis to move with a very small acceleration so we can check the MathBlock is working
axis.AmpEnableSet(true); // Enable the motor.
axis.MoveVelocity(VELOCITY, ACCELERATION);
// wait several samples so we know the RMP is now processing the move command and accelerating
controller.SampleWait(10);
// keep in mind firmware velocity is in counts per sample squared, so we need to convert to UserUnits per second squared
double calculatedAccelerationCountsPerSampleSquared = controller.MathBlockProcessValueGet(SUBTRACTION_MATHBLOCK_INDEX).Double;
// reduce the velocity back to 0
axis.MoveVelocity(0, ACCELERATION);
axis.MotionDoneWait(); // Wait for the axis to finish moving.
axis.AmpEnableSet(false); // Disable the motor.
// convert to UserUnits per second squared
double calculatedAcceleration = calculatedAccelerationCountsPerSampleSquared * controller.SampleRateGet() * controller.SampleRateGet() / axis.UserUnitsGet();
Console.WriteLine($"Calculated acceleration from MathBlock: {calculatedAcceleration}");
// check that the newly calculated acceleration is as expected
if (Math.Abs(calculatedAcceleration - ACCELERATION) <= 0.000001)
Console.WriteLine("The MathBlock is calculating the Axis' acceleration by subtracting previous velocity from current velocity.");
return 0;
Console.WriteLine("Error: The MathBlock is not calculating the Axis' acceleration as expected.");
return -1;
return -1;
static void SetupControllerForHardware(MotionController controller)
static MotionController CreateController()
Creates the MotionController object, using creation parameters.
static void SetupControllerForPhantoms(MotionController controller, int axisCount, int[] axisNums)
HelperFunctionsCS class provides static methods for common tasks in RMP applications.
double UserUnitsGet()
Definition rsi.h:5789
Configure a User Limit.
Definition rsi.h:800
void AxisRemoveAll()
void AxisAdd(Axis *axis)
Definition rsi.h:10701
int32_t MotionDoneWait()
RSIState StateGet()
MathBlock operations.
Definition rsienums.h:1401
RSIDataType
Definition rsienums.h:659
RSIUserLimitLogic
Definition rsienums.h:646
Definition rsienums.h:1112
Definition rsienums.h:434
Trigger types for UserLimits.
Definition rsienums.h:633
Definition rsi.h:3816
double Double
Definition rsi.h:477
