PointToPoint.cpp
Attention
See the following Concept pages for a detailed explanation of this sample: Final Velocity Motion, Absolute Motion, Relative Motion, S-Curve Motion, Velocity Motion.
#include <cmath>
// Helper function to wait for the axis to reach velocity when performing a velocity move or move with final velocity
static void HelperAtVelocityWait(MotionController *controller, Axis *axis, const int timeout)
// The number of samples to wait before checking if the axis is at velocity
const int WAIT_SAMPLES = 100;
int samplesWaited = 0;
while (axis->StatusBitGet(RSIEventType::RSIEventTypeMOTION_AT_VELOCITY) == 0)
controller->SampleWait(WAIT_SAMPLES);
samplesWaited += WAIT_SAMPLES;
if (samplesWaited > timeout)
throw std::runtime_error("Timeout waiting for motion to reach velocity");
int main()
const std::string SAMPLE_APP_NAME = "Motion: Point-to-Point";
/* CONSTANTS */
const int NUM_AXES = 1; // The number of axes to configure
const int AXIS_INDEX = 0; // The index of the axis to configure
// Motion Parameters
const double POSITION_0 = 0;
const double POSITION_1 = 0.5;
const double VELOCITY = 1;
const double ACCELERATION = 10;
const double DECELERATION = 10;
const double FINAL_VELOCITY = 0.5;
// Create the controller
MotionController *controller = MotionController::Create(&params);
int exitCode = -1;
// Prepare the controller as defined in SampleAppsHelper.h depending on the configuration
SampleAppsHelper::SetupController(controller, NUM_AXES);
/* SAMPLE APP BODY */
// Normally you would set the number of axes here, but for samples that is handled in the SampleAppsHelper::SetupController function
// Get the axes
// Specify a timeout for waiting for the motion to complete
const int32_t TIMEOUT = 10000;
// Clear faults and enable the motor
axis->ClearFaults();
axis->AmpEnableSet(true);
/* Absolute (Trapezoidal) Motion */
std::cout << "Absolute (Trapezoidal) Motion:" << std::endl;
axis->MoveTrapezoidal(POSITION_1, VELOCITY, ACCELERATION, DECELERATION);
axis->MotionDoneWait(TIMEOUT);
axis->MoveTrapezoidal(POSITION_0, VELOCITY, ACCELERATION, DECELERATION);
/* Relative Motion */
std::cout << "Relative Motion:" << std::endl;
axis->MoveRelative(POSITION_1 - POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
axis->MoveRelative(POSITION_0 - POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
/* SCurve Motion */
std::cout << "SCurve Motion:" << std::endl;
axis->MoveSCurve(POSITION_1);
axis->MoveSCurve(POSITION_0);
/* SCurve Motion with Final Velocity */
std::cout << "SCurve Motion with Final Velocity:" << std::endl;
std::cout << "Final Velocity: " << FINAL_VELOCITY << std::endl;
axis->MoveSCurve(POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, FINAL_VELOCITY);
HelperAtVelocityWait(controller, axis, TIMEOUT);
std::cout << "Final Velocity: " << 0 << std::endl;
axis->MoveSCurve(POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, 0);
/* Velocity Move */
std::cout << "Velocity Move:" << std::endl;
std::cout << "Accelerating to velocity: " << VELOCITY << std::endl;
axis->MoveVelocity(VELOCITY, ACCELERATION);
std::cout << "Decelerating to velocity: " << 0 << std::endl;
axis->MoveVelocity(0, DECELERATION);
// Return to the original position
// Disable the motor
axis->AmpEnableSet(false);
exitCode = 0; // Set the exit code to success.
exitCode = -1;
// Clean up the controller and any other objects as needed
controller->Delete();
Definition rsi.h:5870
Definition rsi.h:800
int32_t MotionDoneWait()
Definition rsi.h:866
