◆ HomeJerkPercentGet() [1/2]
double HomeJerkPercentGet ( )
HomeJerkPercentGet gets the jerk percent used for homing.
(double) percent (0.0 to 100.0)
Axis: Homing
// get rmp controller
return;
Axis axis = controller.AxisGet(axisNumber: 0);
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Set the home velocity.
void Home()
Execute the homing routine.
bool HomeStateGet()
Get the home state.
Definition rsi.h:5863
Definition rsienums.h:568
Definition rsienums.h:1116
Home
Master-based homing diagrams.
