HelperFunctions.cs
Attention
See the following Concept pages for a detailed explanation of this sample: Helper Functions.
using RSI.RapidCode.dotNET; // Import our RapidCode Library
using System;
using NUnit.Framework;
#endif
public static class HelperFunctions
public static void CheckErrors(RapidCodeObject rsiObject)
bool hasErrors = false;
System.Text.StringBuilder errorStringBuilder = new System.Text.StringBuilder();
while (rsiObject.ErrorLogCountGet() > 0)
RsiError error = rsiObject.ErrorLogGet();
if (error.isWarning)
errorStringBuilder.AppendLine("WARNING: " + error.Message);
hasErrors = true;
errorStringBuilder.AppendLine("ERROR: " + error.Message);
if (errorStringBuilder.Length > 0)
Console.WriteLine(errorStringBuilder.ToString());
if (hasErrors)
throw new Exception(errorStringBuilder.ToString());
public static void StartTheNetwork(MotionController controller)
// Initialize the Network
if (controller.NetworkStateGet() != RSINetworkState.RSINetworkStateOPERATIONAL) // Check if network is started already.
Console.WriteLine("Starting Network..");
controller.NetworkStart(); // If not. Initialize The Network. (This can also be done from RapidSetup Tool)
if (controller.NetworkStateGet() != RSINetworkState.RSINetworkStateOPERATIONAL) // Check if network is started again.
int messagesToRead = controller.NetworkLogMessageCountGet(); // Some kind of error starting the network, read the network log messages
Console.WriteLine(controller.NetworkLogMessageGet(i)); // Print all the messages to help figure out the problem
Console.WriteLine("Expected OPERATIONAL state but the network did not get there.");
//throw new RsiError(); // Uncomment if you want your application to exit when the network isn't operational. (Comment when using phantom axis)
Console.WriteLine("Network Started");
public static class Constants
public const int SAMPLES = 2;
public const int AXIS_NUMBER = 0;
public const int X_AXIS_NUMBER = 0;
public const int Y_AXIS_NUMBER = 1;
public const int Z_AXIS_NUMBER = 2;
public const int A_AXIS_NUMBER = 3;
public const int B_AXIS_NUMBER = 4;
public const int C_AXIS_NUMBER = 5;
public const int MAIN_AXIS_NUMBER = 0;
public const int DRIVEN_AXIS_NUMBER = 1;
public const int HOLDING_AXIS_INDEX = 0;
public const int MOVING_AXIS_INDEX = 1;
public const int AXIS_COUNT = 6;
public const int FIRST_AXIS_NUMBER = 0;
public const int SECOND_AXIS_NUMBER = 1;
public const int THIRD_AXIS_NUMBER = 2;
public const double USER_UNITS = 1;
public const double AKD_USER_UNITS = 1048576; // USER UNITS for an AKD drive 1 rev (the motor used in this sample app has 1048576 encoder pulses per revolution)
public const double POSITION = 2; // Specify the position to travel to.
public const double VELOCITY = 200; // Specify your velocity. - units: UserUnits/Sec
public const double ACCELERATION = 100; // Specify your acceleration. - units: UserUnits/Sec^2
public const double DECELERATION = 100; // Specify your deceleration. - units: UserUnits/Sec^2
public const double JERK_PERCENT = 50; // Specify your jerk percent (0.0 to 100.0)
public const double POSITION_A = 5;
public const double POSITION_B = 10;
public const int MAX_TEST_TIME = 3000;
public const int COMP_NUM_ZERO = 0;
public const int COMP_NUM_ONE = 1;
public const int COMP_NUM_TWO = 2;
public class TestBase
public MotionController controller;
public Axis axis;
public Axis x_axis;
public Axis y_axis;
public Axis z_axis;
public Axis a_axis;
public Axis b_axis;
public Axis c_axis;
public Axis prime_axis;
public Axis main_axis;
public Axis driven_axis;
public MultiAxis jointsMultiAxis;
public Robot robot;
public Axis CreateAndReadyAxis(int AxisNumber)
Axis axis = controller.AxisGet(AxisNumber); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
HelperFunctions.CheckErrors(axis); // [Helper Function] Check that the axis has been initialize correctly.
ResetAxis(axis);
return axis;
public void InitializeAllAxes()
axis = controller.AxisGet(Constants.AXIS_NUMBER); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
x_axis = controller.AxisGet(Constants.X_AXIS_NUMBER);
y_axis = controller.AxisGet(Constants.Y_AXIS_NUMBER);
z_axis = controller.AxisGet(Constants.Z_AXIS_NUMBER);
a_axis = controller.AxisGet(Constants.A_AXIS_NUMBER);
b_axis = controller.AxisGet(Constants.B_AXIS_NUMBER);
c_axis = controller.AxisGet(Constants.C_AXIS_NUMBER);
main_axis = controller.AxisGet(Constants.MAIN_AXIS_NUMBER);
driven_axis = controller.AxisGet(Constants.DRIVEN_AXIS_NUMBER);
jointsMultiAxis = controller.MultiAxisGet(Constants.AXIS_COUNT);
HelperFunctions.CheckErrors(jointsMultiAxis);
public void DisableAllAxes()
for (int i = 0; i < controller.AxisCountGet(); i++)
Axis axis = controller.AxisGet(i);
axis.Abort();
axis.AmpEnableSet(false);
public void ResetAxis(Axis myAxis)
myAxis.UserUnitsSet(Constants.USER_UNITS); // Specify the counts per Unit.
myAxis.PositionSet(0); // Sets the current position as 0 effectively 'homing' it.
myAxis.Abort(); // If there is any motion happening, abort it (creates a fault).
myAxis.DefaultAccelerationSet(Constants.ACCELERATION);
myAxis.DefaultDecelerationSet(Constants.ACCELERATION);
myAxis.DefaultVelocitySet(Constants.VELOCITY);
EnableAmp(myAxis);
public void EnableAmp(Axis myAxis)
myAxis.ClearFaults(); // To enable after an abort faults must be cleared.
myAxis.AmpEnableSet(true); // Enable the motor.
public void TearDownFixture()
DisableAllAxes();
controller.Shutdown();
controller.Delete();
public class SampleAppTestBase : TestBase
[SetUp]
public void SetUp()
//@[AxisGet]
//@[AxisGet]
ResetAxis(axis);
[OneTimeSetUp]
public void OneTimeSetUp()
controller = MotionController.CreateFromSoftware(TestContext.CurrentContext.TestDirectory);// Insert the path location of the RMP.rta (usually the RapidSetup folder)
HelperFunctions.CheckErrors(controller); // [Helper Function] Check that the controller has been initialize correctly.
controller.AxisCountSet(Constants.AXIS_COUNT);
controller.MotionCountSet(Constants.AXIS_COUNT + 1); // Create a MultiAxis
InitializeAllAxes();
[TearDown]
public void TearDown()
DisableAllAxes();
[OneTimeTearDown]
public void OneTimeTearDown()
[TestFixture]
[Category("Software")]
public class StaticMemoryTestBase : TestBase
[OneTimeSetUp]
//@[ControllerReset]
controller.Reset(); // reboot the RMP controller firmware
[SetUp]
public void Setup()
[TearDown]
TearDownFixture(); // Teardown the entire fixture every time as the controller needs to be restarted between different static memory allocations
[TestFixture]
public class HelperFunctionsTests : SampleAppTestBase
[Test]
public void CheckErrorsTest()
string expectedErrorSubstring = "Motion: RSIStateERROR"; // we expect this to be in the message
axis.ThrowExceptions(false); // exceptions will be logged, not thrown
axis.Abort(); // put into RSIStateERROR
axis.MoveSCurve(1); // command a move while in ERROR state - this will log an exception
Assert.Throws(Is.TypeOf<Exception>().And.Message.Contains(expectedErrorSubstring), () => HelperFunctions.CheckErrors(axis));
[Test]
public void CheckErrorsWarningTest()
const int BAD_AXIS_NUMBER = 777;
Axis badAxis = controller.AxisGet(BAD_AXIS_NUMBER); // try to get an illegal axis
Assert.Throws(Is.TypeOf<Exception>().And.Message.Contains(BAD_AXIS_NUMBER.ToString()), () => HelperFunctions.CheckErrors(badAxis));
Definition rsi.h:5870
void DefaultVelocitySet(double velocity)
Set the default velocity in UserUnits.
void Reset()
Reset the controller which stops and restarts the RMP firmware.
void NetworkStart()
Start the network, doing both a discovery followed by starting to OPERATIONAL state.
const char *const NetworkLogMessageGet(int32_t messageIndex)
void Shutdown()
Shutdown the controller.
int32_t AxisCountGet()
Definition rsi.h:800
Definition rsi.h:10804
int32_t ErrorLogCountGet()
Definition rsi.h:184
Definition rsi.h:111
bool isWarning
Definition rsi.h:120
Definition rsienums.h:568
The Cartesian namespace.
