DifferenceOfPositionUserLimit.cpp
Attention
See the following Concept pages for a detailed explanation of this sample: Math Blocks.
#include <map>
using namespace RSI::RapidCode; // Import our RapidCode namespace
// Map of the RSIState enum to string
static const std::map<RSIState, std::string> RSIStateMap = {
{RSIState::RSIStateIDLE, "RSIStateIDLE"},
{RSIState::RSIStateMOVING, "RSIStateMOVING"},
{RSIState::RSIStateSTOPPING, "RSIStateSTOPPING"},
{RSIState::RSIStateSTOPPED, "RSIStateSTOPPED"},
{RSIState::RSIStateSTOPPING_ERROR, "RSIStateSTOPPING_ERROR"},
{RSIState::RSIStateERROR, "RSIStateERROR"}
int main()
const std::string SAMPLE_APP_NAME = "Math Blocks: Difference of Position User Limit";
/* CONSTANTS */
const int NUM_AXES = 2; // The number of axes to configure
const int AXIS_X_INDEX = 0; // The index of the first axis
const int AXIS_Y_INDEX = 1; // The index of the second axis
// User Limit Configuration
const double MAX_POSITION_DIFFERENCE = 0.5; // the maximum position difference before the user limit triggers
const RSIAction USER_LIMIT_ACTION = RSIAction::RSIActionABORT; // the action to take when the user limit is triggered
const int USER_LIMIT_DURATION = 0; // the time delay before the action is executed after the User Limit has triggered
// Motion Parameters
const double RELATIVE_POSITION = 2 * MAX_POSITION_DIFFERENCE; // the relative position to move the axes
const double VELOCITY = 1; // the velocity to move the axes
const double ACCELERATION = 10; // the acceleration of the axes movement
const double DECELERATION = 10; // the deceleration of the axes movement
const double JERK_PCT = 0; // the jerk percentage of the axes movement
// Create the controller
MotionController *controller = MotionController::Create(&params);
// Variables to store initial object counts to restore later (starts at -1 to indicate it has not been set)
int initialUserLimitCount = -1;
int initialMathBlockCount = -1;
int exitCode = -1;
// Prepare the controller as defined in SampleAppsHelper.h depending on the configuration
SampleAppsHelper::SetupController(controller, NUM_AXES);
// Save initial object counts to restore later
initialUserLimitCount = controller->UserLimitCountGet();
initialMathBlockCount = controller->MathBlockCountGet();
/* SAMPLE APP BODY */
/* Configure the controller object counts */
// Normally you would set the number of axes here, but for samples that is handled in the SampleAppsHelper::SetupController function
// Each axis has a motion object associated with it, so we need to add one more motion object than axes
const int multiAxisIndex = controller->AxisCountGet();
controller->MotionCountSet(multiAxisIndex + 1);
const int userLimitIndex = initialUserLimitCount;
controller->UserLimitCountSet(initialUserLimitCount + 1);
const int mathBlockIndex = initialMathBlockCount;
controller->MathBlockCountSet(initialMathBlockCount + 1);
// Get the axes
Axis *axisX = controller->AxisGet(AXIS_X_INDEX);
Axis *axisY = controller->AxisGet(AXIS_Y_INDEX);
// Configure a multiaxis for the two axes
MultiAxis *multiAxis = controller->MultiAxisGet(multiAxisIndex);
multiAxis->AxisRemoveAll();
multiAxis->AxisAdd(axisX);
multiAxis->AxisAdd(axisY);
multiAxis->Abort(); // make sure the multiaxis is not moving
multiAxis->ClearFaults();
// Read the configuration of the MathBlock
MotionController::MathBlockConfig mathBlockConfig = controller->MathBlockConfigGet(mathBlockIndex);
// Determine which axis address type to use based on the config USE_HARDWARE flag
RSIAxisAddressType INPUT_AXIS_ADDRESS_TYPE = (SampleAppsConfig::USE_HARDWARE) ? (RSIAxisAddressType::RSIAxisAddressTypeACTUAL_POSITION)
: (RSIAxisAddressType::RSIAxisAddressTypeCOMMAND_POSITION);
// Configure the MathBlock to subtract the position of the second axis from the position of the first axis
mathBlockConfig.InputAddress0 = axisX->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
mathBlockConfig.InputDataType0 = RSIDataType::RSIDataTypeDOUBLE;
mathBlockConfig.InputAddress1 = axisY->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
mathBlockConfig.InputDataType1 = RSIDataType::RSIDataTypeDOUBLE;
mathBlockConfig.ProcessDataType = RSIDataType::RSIDataTypeDOUBLE;
mathBlockConfig.Operation = RSIMathBlockOperation::RSIMathBlockOperationSUBTRACT;
// Set the MathBlock configuration
controller->MathBlockConfigSet(mathBlockIndex, mathBlockConfig);
// Wait a sample so we know the RMP is now processing the newly configured MathBlocks
controller->SampleWait(1);
std::cout << "MathBlock configured to subtract the position of the second axis from the position of the first axis." << std::endl;
// Get the address of the MathBlock's ProcessValue to use in the UserLimit
uint64_t mathBlockProcessValueAddress =
controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, mathBlockIndex);
// Configure the UserLimit to trigger when the absolute position difference is greater than MAX_POSITION_DIFFERENCE
controller->UserLimitConditionSet(
userLimitIndex, 0, RSIUserLimitLogic::RSIUserLimitLogicABS_GT, mathBlockProcessValueAddress, MAX_POSITION_DIFFERENCE
// Set the UserLimit action to abort motion (Note: since the axes are in a multiaxis, the other axis will also be aborted)
controller->UserLimitConfigSet(
userLimitIndex, RSIUserLimitTriggerType::RSIUserLimitTriggerTypeSINGLE_CONDITION, USER_LIMIT_ACTION, AXIS_X_INDEX,
USER_LIMIT_DURATION
std::cout << "UserLimit configured to trigger when the absolute position difference is greater than " << MAX_POSITION_DIFFERENCE
<< " and abort motion." << std::endl;
// Command motion to trigger the UserLimit
std::cout << "Moving the axes to trigger the UserLimit..." << std::endl;
axisX->AmpEnableSet(true); // Enable the motor.
axisX->MoveRelative(RELATIVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PCT); // Move the axis to trigger the UserLimit.
axisX->MotionDoneWait();
// Disable the motor and the UserLimit
axisX->AmpEnableSet(false); // Disable the motor.
controller->UserLimitDisable(userLimitIndex);
// The motion should have been aborted and both axes should be in an error state
if ((axisX->StateGet() == RSIState::RSIStateERROR) && (axisY->StateGet() == RSIState::RSIStateERROR))
std::cout << "Both axes are in the error state after the UserLimit triggered (This is the intended behavior)." << std::endl;
exitCode = 0;
std::cout << "Error: The axes should be in an error state after the UserLimit triggers, but they are not." << std::endl;
std::cout << "First Axis State: " << RSIStateMap.at(axisX->StateGet()) << std::endl;
std::cout << "Second Axis State: " << RSIStateMap.at(axisY->StateGet()) << std::endl;
exitCode = -1;
exitCode = -1;
if (initialUserLimitCount != -1) { controller->UserLimitCountSet(initialUserLimitCount); }
if (initialMathBlockCount != -1) { controller->MathBlockCountSet(initialMathBlockCount); }
// Note: The axis and motion counts are handled by the SampleAppsHelper::Cleanup function
// Clean up the controller and any other objects as needed
controller->Delete();
Definition rsi.h:5870
int32_t UserLimitCountGet()
Get the number of UserLimits processing in the firmware.
Configure a User Limit.
int32_t MathBlockCountGet()
int32_t AxisCountGet()
Definition rsi.h:800
void AxisRemoveAll()
void AxisAdd(Axis *axis)
Definition rsi.h:10804
int32_t MotionDoneWait()
RSIState StateGet()
Definition rsienums.h:1115
Definition rsienums.h:434
Definition rsi.h:866
RSIDataType ProcessDataType
Data type for processing.
Definition rsi.h:3824
Definition rsi.h:3817
uint64_t InputAddress0
Definition rsi.h:3818
RSIDataType InputDataType0
Definition rsi.h:3819
uint64_t InputAddress1
Definition rsi.h:3820
RSIDataType InputDataType1
Definition rsi.h:3821
Definition rsi.h:3825
static constexpr bool USE_HARDWARE
