CalculateAccelerationFromVelocity.cpp
Attention
See the following Concept pages for a detailed explanation of this sample: Math Blocks.
using namespace RSI::RapidCode; // Import our RapidCode namespace
int main()
const std::string SAMPLE_APP_NAME = "Math Blocks: Calculate Acceleration from Velocity";
/* CONSTANTS */
/* *NOTICE* The following constants must be configured before attempting to run with hardware. */
const int NUM_AXES = 1; // The number of axes to configure
const int AXIS_INDEX = 0; // The index of the axis to configure
const double VELOCITY = 1.0; // the velocity to move the axis
const double ACCELERATION = 0.123; // something small so we can check the MathBlock is working
// Create the Controller
MotionController *controller = MotionController::Create(&params);
// Variables to store initial object counts to restore later (starts at -1 to indicate it has not been set)
int initialMathBlockCount = -1;
int exitCode = -1;
// Prepare the controller as defined in SampleAppsHelper.h depending on the configuration
SampleAppsHelper::SetupController(controller, NUM_AXES);
// Save initial object counts to restore later
initialMathBlockCount = controller->MathBlockCountGet();
/* SAMPLE APP BODY */
/* Configure the controller object counts */
// Normally you would set the number of axes here, but for samples that is handled in the SampleAppsHelper::SetupController function
// Add the two MathBlocks needed for this sample
const int subtractionMathBlockIndex = initialMathBlockCount;
const int previousVelocityMathBlockIndex = initialMathBlockCount + 1;
controller->MathBlockCountSet(initialMathBlockCount + 2);
// Get the axis and make sure the axis is not moving and clear any faults
axis->Abort();
axis->ClearFaults();
// Read the configuration of both MathBlocks
MotionController::MathBlockConfig subtractionConfig = controller->MathBlockConfigGet(subtractionMathBlockIndex);
// This index must be greater than the subtraction math block index, so the subtraction data is
// one sample old
MotionController::MathBlockConfig previousVelocityConfig = controller->MathBlockConfigGet(previousVelocityMathBlockIndex);
// Set the axis to use the command velocity as the input for the MathBlock
RSIAxisAddressType INPUT_AXIS_ADDRESS_TYPE = RSIAxisAddressType::RSIAxisAddressTypeCOMMAND_VELOCITY;
// Configure the first MathBlock to subtract the previous velocity from the current velocity
// Current velocity:
subtractionConfig.InputAddress0 = axis->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
subtractionConfig.InputDataType0 = RSIDataType::RSIDataTypeDOUBLE;
// Previous velocity: (as was calculated by the second MathBlock, so we use its ProcessValue)
subtractionConfig.InputAddress1 =
controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, previousVelocityMathBlockIndex);
subtractionConfig.InputDataType1 = RSIDataType::RSIDataTypeDOUBLE;
subtractionConfig.ProcessDataType = RSIDataType::RSIDataTypeDOUBLE;
subtractionConfig.Operation = RSIMathBlockOperation::RSIMathBlockOperationSUBTRACT;
// Write 1.0 to the first UserBuffer entry so the second MathBlock can use it for multiplication
uint64_t userBufferAddr0 = controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeUSER_BUFFER, 0);
controller->MemoryDoubleSet(userBufferAddr0, 1.0);
// Configure the second MathBlock to multiply the current velocity by 1.0 (which we'll use for
// the previous sample's velocity)
previousVelocityConfig.InputAddress0 = axis->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
previousVelocityConfig.InputDataType0 = RSIDataType::RSIDataTypeDOUBLE;
previousVelocityConfig.InputAddress1 = userBufferAddr0;
previousVelocityConfig.InputDataType1 = RSIDataType::RSIDataTypeDOUBLE;
previousVelocityConfig.ProcessDataType = RSIDataType::RSIDataTypeDOUBLE;
previousVelocityConfig.Operation = RSIMathBlockOperation::RSIMathBlockOperationMULTIPLY;
// Set the MathBlock configurations
controller->MathBlockConfigSet(subtractionMathBlockIndex, subtractionConfig);
controller->MathBlockConfigSet(previousVelocityMathBlockIndex, previousVelocityConfig);
// Wait a sample so we know the RMP is now processing the newly configured MathBlocks
controller->SampleWait(1);
// Set the axis to move with a very small acceleration so we can check the MathBlock is working
axis->AmpEnableSet(true); // Enable the motor.
axis->MoveVelocity(VELOCITY, ACCELERATION);
// Wait several samples so we know the RMP is now processing the move command and accelerating
controller->SampleWait(10);
// Keep in mind firmware velocity is in counts per sample, so we need to convert to UserUnits
// per second squared
double calculatedVelocityDelta = controller->MathBlockProcessValueGet(subtractionMathBlockIndex).Double;
// Reduce the velocity back to 0
axis->MoveVelocity(0, ACCELERATION);
axis->MotionDoneWait(); // Wait for the axis to finish moving.
axis->AmpEnableSet(false); // Disable the motor.
// Convert to UserUnits per second squared
double calculatedAcceleration = calculatedVelocityDelta * controller->SampleRateGet() * controller->SampleRateGet() / axis->UserUnitsGet();
std::cout << "Calculated acceleration from MathBlock: " << calculatedAcceleration << std::endl;
// Check that the newly calculated acceleration is as expected
if (std::abs(calculatedAcceleration - ACCELERATION) <= 0.000001)
std::cout << "The MathBlock is calculating the Axis' acceleration by subtracting previous velocity from current velocity." << std::endl;
exitCode = 0;
std::cerr << "Error: The calculated acceleration does not match the expected value" << std::endl;
exitCode = -1;
exitCode = -1;
if (initialMathBlockCount != -1) { controller->MathBlockCountSet(initialMathBlockCount); }
// Note: The axis count is handled by the SampleAppsHelper::Cleanup function
// Clean up the controller and any other objects as needed
controller->Delete();
double UserUnitsGet()
Definition rsi.h:5862
int32_t MathBlockCountGet()
Definition rsi.h:800
int32_t MotionDoneWait()
Definition rsienums.h:434
Definition rsi.h:866
RSIDataType ProcessDataType
Data type for processing.
Definition rsi.h:3818
Definition rsi.h:3811
uint64_t InputAddress0
Definition rsi.h:3812
RSIDataType InputDataType0
Definition rsi.h:3813
uint64_t InputAddress1
Definition rsi.h:3814
RSIDataType InputDataType1
Definition rsi.h:3815
Definition rsi.h:3819
double Double
Definition rsi.h:477
