AxisConfiguration.cpp
Attention
See the following Concept pages for a detailed explanation of this sample: Counts Per Unit (User Units), Hardware Limits, Settling, Stopping Rates.
#include <cmath>
int main()
const std::string SAMPLE_APP_NAME = "Axis Configuration";
/* CONSTANTS */
const int NUM_AXES = 1; // The number of axes to configure, default is 0 for this template
const int AXIS_INDEX = 0; // The index of the axis to configure
// Create the controller
MotionController *controller = MotionController::Create(&params);
int exitCode = -1;
// Prepare the controller as defined in SampleAppsHelper.h depending on the configuration
SampleAppsHelper::SetupController(controller, NUM_AXES);
/* SAMPLE APP BODY */
// Normally you would set the number of axes here, but for samples that is handled in the SampleAppsHelper::SetupController function
// Get the axes
/* Amp Fault Configuration */
std::cout << "Configuring Amp Fault parameters\n" << std::endl;
// Parameters
const double AMP_FAULT_DURATION_TIME = 1; // How long the axis must be in the trigger state to be considered an amp fault.
const RSIAction AMP_FAULT_ACTION = RSIAction::RSIActionABORT; // The action to take when an amp fault occurs.
const int AMP_FAULT_TRIGGER_STATE = 1; // The state that triggers the amp fault, active high = 1, active low = 0.
// SET
axis->AmpEnableSet(false); // Disable the axis
axis->AmpFaultDurationSet(AMP_FAULT_DURATION_TIME);
axis->AmpFaultActionSet(AMP_FAULT_ACTION);
axis->AmpFaultTriggerStateSet(AMP_FAULT_TRIGGER_STATE);
// GET
double durationTime = axis->AmpFaultDurationGet();
RSIAction action = axis->AmpFaultActionGet();
int triggerState = axis->AmpFaultTriggerStateGet();
std::cout << "Axis Amp Fault parameters have been set" << std::endl;
/* Hardware Limits Configuration */
std::cout << "Configuring Hardware Limits parameters\n" << std::endl;
// Parameters
const int TRIGGER_STATE = 1; // The state that triggers the positive software limit, active high = 1, active low = 0.
const double DURATION = 0.01; // How long the hardware limit must be in the trigger state to be considered triggered.
const RSIAction ACTION = RSIAction::RSIActionABORT; // The action to take when the positive hardware limit is triggered.
// SET
axis->HardwarePosLimitTriggerStateSet(TRIGGER_STATE);
axis->HardwarePosLimitDurationSet(DURATION);
axis->HardwareNegLimitTriggerStateSet(TRIGGER_STATE);
axis->HardwareNegLimitDurationSet(DURATION);
// GET
int posTriggerState = axis->HardwarePosLimitTriggerStateGet();
double posDuration = axis->HardwarePosLimitDurationGet();
RSIAction posAction = axis->HardwarePosLimitActionGet();
int negTriggerState = axis->HardwareNegLimitTriggerStateGet();
double negDuration = axis->HardwareNegLimitDurationGet();
RSIAction negAction = axis->HardwareNegLimitActionGet();
std::cout << "Axis Hardware Limits have been set" << std::endl;
/* Settling Configuration */
std::cout << "Configuring Settling parameters\n" << std::endl;
// Parameters
const double POSITION_TOLERANCE_FINE = 200; // Tolerance for when a move is considered complete.
const double POSITION_TOLERANCE_COARSE = 300; // Tolerance for when a move is considered "near" complete.
const double VELOCITY_TOLERANCE = 12000; // Tolerance for when a velocity move is considered complete.
const double SETTLING_TIME = 5; // How long the axis must be within tolerance to be considered settled.
// SET
axis->PositionToleranceFineSet(POSITION_TOLERANCE_FINE);
axis->PositionToleranceCoarseSet(POSITION_TOLERANCE_COARSE);
axis->VelocityToleranceSet(VELOCITY_TOLERANCE);
axis->SettlingTimeSet(SETTLING_TIME);
// GET
double posTolFine = axis->PositionToleranceFineGet();
double posTolCoarse = axis->PositionToleranceCoarseGet();
double velTol = axis->VelocityToleranceGet();
double setTime = axis->SettlingTimeGet();
std::cout << "Axis Settling parameters have been set" << std::endl;
/* Stop Rate Configuration */
std::cout << "Configuring Stop Rate parameters\n" << std::endl;
// Parameters
const double STOP_RATE_DEFAULT = 1.0; // Specify the default STOP rate in seconds.
const double ESTOP_RATE_DEFAULT = 0.05; // Specify the default ESTOP rate in seconds.
const double ESTOP_DECELERATION_RATE = 1000; // Specify the default ESTOP deceleration rate in seconds.
// SET
axis->StopTimeSet(STOP_RATE_DEFAULT);
axis->EStopTimeSet(ESTOP_RATE_DEFAULT);
axis->EStopDecelerationSet(ESTOP_DECELERATION_RATE);
// GET
double stopRate = axis->StopTimeGet();
double eStopRate = axis->EStopTimeGet();
double eStopDeceleration = axis->EStopDecelerationGet();
std::cout << "Axis Stop Rate parameters have been set" << std::endl;
/* User Units Configuration */
std::cout << "Configuring User Units parameters\n" << std::endl;
// Parameters
const int ENCODER_RESOLUTION_BITS = 20; // The number of bits defining the encoder resolution
const double USER_UNITS = std::pow(2, ENCODER_RESOLUTION_BITS); // The number of user units per revolution
// (2^20 = 1,048,576 user units per revolution)
// SET
// GET
double userUnits = axis->UserUnitsGet();
std::cout << "Axis User Units have been set" << std::endl;
exitCode = 0; // Set the exit code to success.
exitCode = -1;
// Clean up the controller and any other objects as needed
controller->Delete();
RSIAction AmpFaultActionGet()
Get the Amp Fault action.
double SettlingTimeGet()
Get the Settling time.
double UserUnitsGet()
sets the trigger state.
Set the Amp Fault action.
double AmpFaultDurationGet()
trigger state return.
double EStopDecelerationGet()
double VelocityToleranceGet()
Trigger state return.
Sets the trigger state.
Set the settling time.
Definition rsi.h:5862
Definition rsi.h:800
double EStopTimeGet()
double StopTimeGet()
Definition rsienums.h:1115
Definition rsi.h:866
