#include <iomanip>
#include "SampleAppsHelper.h"
#include "rsi.h"
static std::vector<int> MinMaxAvg(std::vector<int> data)
  int min = data[0];
  int max = data[0];
  int sum = 0;
  for (int i = 0; i < data.size(); i++)
    if (data[i] < min)
      min = data[i];
    if (data[i] > max)
      max = data[i];
    sum += data[i];
  int avg = sum / data.size();
  return {min, max, avg};
int main()
  const std::string SAMPLE_APP_NAME = "Utilities: Record Performance";
  const int RECORD_PERIOD_SAMPLES = 1;
  const int RECORD_TIME = 1000;
  int exitCode = -1;
    int valuesPerRecord;
    bool networkTimingEnabled = false;
    if (controller->
NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL)
      std::cout << "Network is not operational. Only Firmware Timing Deltas will be recorded." << std::endl;
      valuesPerRecord = 1;
      networkTimingEnabled = true;
      valuesPerRecord = 3;
    if (networkTimingEnabled)
    controller->
OS->
Sleep(RECORD_TIME);
    std::cout << "There are " << recordCount << " records available." << std::endl;
    std::vector<int> firmawareTimingDeltas(recordCount);
    std::vector<int> networkTimingDeltas(recordCount);
    std::vector<int> networkTimingReceiveDeltas(recordCount);
    for (int i = 0; i < recordCount; i++)
    std::vector<int> firmwareTimingStats = MinMaxAvg(firmawareTimingDeltas);
    std::cout << "Firmware Timing Deltas (us):       ";
    std::cout << "  Min = " << std::setw(4) << firmwareTimingStats[0];
    std::cout << "  Max = " << std::setw(4) << firmwareTimingStats[1];
    std::cout << "  Avg = " << std::setw(4) << firmwareTimingStats[2] << std::endl;
      std::vector<int> networkTimingStats = MinMaxAvg(networkTimingDeltas);
      std::cout << "Network Timing Deltas (us):        ";
      std::cout << "  Min = " << std::setw(4) << networkTimingStats[0];
      std::cout << "  Max = " << std::setw(4) << networkTimingStats[1];
      std::cout << "  Avg = " << std::setw(4) << networkTimingStats[2] << std::endl;
      std::vector<int> networkTimingReceiveStats = MinMaxAvg(networkTimingReceiveDeltas);
      std::cout << "Network Timing Receive Deltas (us):";
      std::cout << "  Min = " << std::setw(4) << networkTimingReceiveStats[0];
      std::cout << "  Max = " << std::setw(4) << networkTimingReceiveStats[1];
      std::cout << "  Avg = " << std::setw(4) << networkTimingReceiveStats[2] << std::endl;
    exitCode = 0;
    exitCode = -1;
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
int32_t RecorderCountGet()
Get the number of Recorder available in the firmware.
bool RecorderEnabledGet()
RapidCodeOS * OS
void NetworkTimingEnableSet(bool enable)
Enable or disable the firmware to start timing the network packets.
